Pls i have a cyberhome ch-dvd player with model number:ch-dvd 300 zsi and dvd drive model no DP02CD. Can you pls give me the optical lens pick up nomber for a replacement.
That problem is cause of dusty or defective optical cd lens..
please try to clean it the lens or replace it to fix your problem..
if you need specific solution and more help...Please try to click this " Fix No-disc error on DVDs" and try to purchse my service.. Thank you for using fixya..
hello, you can fixed this by opening the back cover of the player. Use a dry cotton bud to clean the lens be very careful because it fragile. Also observe the red beam up of light on the lens when the player is power is on , if it does not beam,the problem could be the lens or the ribbon cable used to connect the lens to the printed circuit board. if any is found faulty replace for a new one for better effectiveness
I have CH DVD 300 Model, i have purchased this DVD on 2007, yestarday (17/05/2009).
When i put DVD in, i cannot see any screen on TV, perviosly i can seen default screen CYBERHOME, all other things are ok, (powe on ok, eject & incert ok,) dvd is not playing after putting DVD in CYBERHOME.
First check the power supply for bulging capacitors,and burned componants,these units stay on,even thogh you power the unit off,,unplug when not using
Replacec-10,and c-11 filter caps
