Acer Aspire 5003 Thermal Module
I have a replacement Acer laptop thermal module assembly (integral fan+heat pipe+CPU heat sink) for the subject laptop. The heat sink surface that will contact the CPU already has what appears to be a black plastic mylar film attached tothe metal plate with a rectangular silver pad inlay in its center. Is this to be used with or without heat sink compound to assure intimate thermal contact with the CPU surface?
Greetings,
I believe that the 'silver pad' you are talking about is likely a thermal pad which creates intimate thermal contact in the same manner as a thermal compound. As long as the pad has not deteriorated then you can reuse it. If that helped please rate me well.
For Reference:
http://www.radioshack.com/product/index.jsp?productId=2295074
Take Care,
-WN
Posted on Jun 05, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Yes, and you need to get some themral paste insure that it has good contact. I hope this helps lala linda
Acer aspire 5750-4885
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
May 07, 2013 | Acer Computers & Internet
Acer aspire 5335 switches on then goes off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
Dec 06, 2012 | Acer Aspire 5335 PC Notebook
My acer aspire one netbook is freezing whenever i stay on it for more then an hour,my laptop has no virus, i think it is the cpu usage..how do i fix this?
Dec 06, 2012 | Acer Aspire One A150-1006 Notebook
Acer guet hot end shut down
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 02, 2012 | Acer Aspire 5315 Notebook
My 5100 acer over heats and the curer runs on
May 03, 2012 | Acer Aspire 5100 Notebook
Acer Aspire 4930 heats up very quickly
Mar 28, 2012 | Acer Aspire 4930-6862 Laptop
My Laptop, ACER ASPIRE 5738G overheats during gaming. When it reaches a temp more than 70 C it shuts down. I tried unscrewing it to blow out the vents.. but the casing doesnt want to come loose. i...
Gaming (and graphics application) consumes more CPU/ Processor resources and due to the heavy processing the PC (CPU & GPU) heatup. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ GPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not it needs replacement)
2. Clean the fan and heat sink (thermal module). Click here for GENERAL Acer Laptop disassembly instructions and refer to
Removing the System Fan/Thermal Module after removing the outer cover. Take out the fan and heat sink. clean them with the help of tooth brush and put it back. Also, repair manual can be searched online or downloaded for referrence.
The procedure is very simple, but if you are not comfortable with working inside electronics, I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
May 02, 2011 | Computers & Internet
My acer aspire 8930 9600m gt gpu keeps overheating what is the problem
2. Clean the fan and heat sink (thermal module). Click here for laptop disassembly instructions and refer to
CreativeTECH
Apr 16, 2011 | Acer Aspire AS5252V333 Notebook
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
ACER ASPIRE 3000 gets power off after some time automatically
If the laptop shuts down by itself and deosn't boot up again after some time, then the problem could be an over heating problem. The CPU shuts down when it overheats (thermal shutdown) and it is usually caused by a faulty fan and or the fan and heat-sink is clogged with dust.
Check the fan and if it does not spin freely then replace the fan and or remove the dust from the fan and heat-sink assembly.
Oct 12, 2009 | Acer Aspire 3000 Notebook
Computers & Internet Logo
1,151 people viewed this question
David Payne
David Payne
