Question about Acer Aspire™ T180 PC Desktop
Boot up problems and running very slow
After the windows xp screen comes up, it stays on the green acer screen forever before it makes an attempt to boot up. It takes 15 to 30 mins for the user log in screen to come up. after logging in, almost 10 mins for desktop screen and another 15 mins for the icons to appear. then it operates very slow and erratic. the icons sometimes dissappear then you can't do anything
  • 1 more comment
  • Anonymous Jun 06, 2008
    computer will not boot. black screen.
  • varri_kk Sep 15, 2008
    my pc started with safemode only,running veryslowly
  • navinnair Jan 04, 2009
    Problem With my PC too. Installed TuneUp Utilities 2008 & Ran the scan check disk function. It scanned & after reported that my C: required me to rescan again after it restarts windows.
    Thats the last i saw of windows... Now my system DOESN'T BOOT AT ALL!
    Sniper:
  • 62 Answers
The problem is that you have lots of starup item in your Msconfig.
You need to disable all the startup items and some none Microsoft services.
Start->run->Msconfig Now you can disable services and startup items.
Instead of using this you can use
1. TuneUp-Utilities-2008:
(http://www.tune-up.com/download/tu2008/)
OR
You can run good anti spyware on system from
http://www.bleepingcomputer.com/malware-removal/uninstall-antivirus-2009
and run this tool
Posted on Sep 17, 2008
When i turn on my acer aspire t180 desktop, thats all it says is. del; enter setup f12;boot menu.but nothing happenens. please help
Posted on May 04, 2009
    Scholar:
  • 63 Answers
How about I make it simple:
Download and run:
http://www.malwaresupport.com/mbam/program/mbam-setup.exe
Called malwarebytes antimalware; it's free. I use it three times a day. superantispyware is not bad, but malwarebytes will remove it in a quick scan without needing to go to safe mode. regardless, my suggestion download BOTH run BOTH in a full scan, start with malware bytes full scan after updating them both. then reboot and run full scan of the superantispyware as well, do this for every login. it will also fix the hijacked backround, and the missing tabs in video properties. which I can also help you with but it should do this for you automatically, also NOD32 will keep it out once it's removed:
http://www.newegg.com/Product/Product.aspx?Item=N82E16832114005
If it's not spyware, then it's probably one these things, either the motherboard has bad capacitors, the power supply is not doing it's job. or the hard drive is starting to lag. High latency when reading sectors on a disk is a common speed issue. there is a program called MHDD:
http://hddguru.com/content/en/software/2005.10.02-MHDD/
and if you get any more than a hundred sectors over 10 MS then you have a drive that is begining to fail you may notice patterns as you scan it, this is the hard drive balancing the read/write sectors so that the wear is even. if the hard drive is ok then it's motherboard/power supply.
Posted on Jul 22, 2008
    Producer:
    Uploaded 30 video answers.
  • 95 Answers
Hi MadSyNTis,
Slow boot problems on any computers are due to 2 reasons :
(1) Hardware reasons and
(2)Software reasons
(TRY THE SOLUTION MENTIONED FOR SOFTWARE FIRST, IF THAT DOES NOT HELP, ONLY THEN TRY THE HARDWARE SOLUTION)
HARDWARE REASONS> if your system has less RAM (memory) then it can cause slow boot up issues,
SOLUTION FOR HARDWARE > I recommend you to check the amount of memory on your system., to check the memory on your system , click on start , then "right click" on "my computer " icon and select properties.. on the screen you will the the amount of RAM installed. I recommend 1 GB of RAM on a computer.
SOFTWARE REASONS> These can be a problem with the windows XP operating system.
SOLUTION FOR SOFTWARE> perform the steps as mentioned in the following links :
http://www.microsoft.com/atwork/getstarted/speed.mspx
(Click on the above link)
NOTE>The above steps are safe to try and do not result in any kind of data loss.
GoodLuck :-)
Posted on Jun 05, 2008
It sounds like you have a spyware/virus issue on your computer.
When your computer is booting up (Before the Windows XP screen appears), press F8 on your keyboard. A list of options will appear, choose safe mode (Not safe mode with networking).
When you get into windows, go to Start -> Run, and type "msconfig" without the quotes. A window will appear, go to the "startup" tab and hit the button labeled "Disable all". Hit apply, close the box and choose to restart the computer. What this does is stop all programs except just windows from starting up with your computer, which should significantly increase bootup and run speed of your computer.
From there, you should run an anti-virus and anti-spyware program to remove any infections on your computer.
A popular free anti-virus is AVG, located at free.grisoft.com.
For spyware I would reccomend Ad-aware 2008, which you can find at
http://www.download.com/Ad-Aware-2008/3000-8022_4-10045910.html
Reinstala xp, y si el problema persiste revisa tu pc por dentro tal vez el problema sea de hardware
  • 121 Answers
Try to reinstall windows if it didnt work chek ram if compatible and installed properly.
I have a Compaq that runs on Windows XP. Every time I try to boot up the computer, I get stuck on the ''Detecting IDE Drives''. Furthermore, on the bottom of the screen it says ''Press for setup''. I...
This seems like a problem with hard drive. It is possible that it has failed. Before we come to this decision you need to try and run recovery console form windows cd. It can be as simple as bad Master Boot Record. Run recovery console and follow the prompts on how to do the repair.
Jan 06, 2010 | Computers & Internet
To stop acer logo before starting windows xp
Well, Firstly this might be a extreme case but is to reformat your hard drive removing any manufactures partition, and reinstalling the Operating System, but what i would do first is the go to start---run---(type this command and hit enter)"msconfig" the system configuration window should pop up. Go to the boot tab and place check mark in the box which says "No GUI boot" you mat also change the timeout seconds there too. hit apply then OK and reboot your system.
hope this works for you. let met know.
Oct 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
PC shuts down while running Windows
Attempt to boot the machine in Safe-Mode.
While powering up continuously hit F8.
You will get a Boot Option Menu, Select Safe-Mode boot
If you can get into safe-mode I would suggest to try doing an online scan, as it sounds like your issue could be related to malware:
www.trendmicro.com/housecall
Let us know
Good luck
Apr 15, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Brand new notebook .. windows then, screen freeze..acer picture
This may require a "repair" of windows.
Get a Windows XP Operating system disk with the correct service pack that the notebook has installed (usually XP SP2).
1. Boot from it (put it in CD drive and restart the laptop).
2. If you still get the same problem start up, you need to set the laptop to boot from CD.
3. Restart laptop, press Delete key or F2, or F12 (it should say one of these on the screen) to enter the Setup. or another key to get "boot options"
4. In Setup (BIOS) Use Right Arrow to find the Boot Options. Use the instructions to move the CD-ROM to first position, above HDD (hard drive). Press Esc, then F10 to save your changes and exit.
5. The XP CD Rom should now run. It should come to a screen where you are asked to press R to repair windows.
6. When it comes to the command prompt, restart the laptop
Hopefully the laptop should boot OK again.
Jan 25, 2009 | Acer Aspire One PC Notebook
Acer Aspire E571, stuck on "ACER" screen
Have you tryed unplugging the HD and seeing if you can access the cmos?
Dec 06, 2008 | Acer Aspire 5610-4648 Notebook
Slow boot after installing the HP 4380
i have this problem with the hp F4240 and even if the printer is not hooked up at all
Aug 11, 2008 | Office Equipment & Supplies
Aspire 3610 fails to run for more than a few minutes
does the laptop get very hot ? Aspire know to over heat.
You also might want to reinstall OS.
May 08, 2008 | Acer Aspire 3610 Notebook
Laptop Wont Boot
Does it sound like it's starting up at all? Is the problem that only the screen turns blank? You might have just disabled the standard output. Try pressing Fn (bottom left on the keyboard) and the F5 on the top a few times to see if the screen toggles back on. You might also try to run it without the battery, and on the battery only in case it's a faulty battery or power supply that causes the problem. If not, it sounds lsike a serious problem, so if there is any chance of the waranty still being valid I'd call acer support asap.
Jun 17, 2007 | Acer Aspire 3000 Notebook
Acer Aspire™ T180 PC Desktop Logo
248 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
