okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used untill the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser overtemp means the fixing assy has exceeded the manufacures maximun temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no responce means the fixing assy didnt even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arow buttons to scroll to #4 printer reset press set.press the approprite arrow key under the YES to clear the error. unplg the copier and reboot. At this time normal function should return if not and it resets a E00 the nyou can assume either the fixing asy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to reserch the problem to avoid spending money on excess parts
My cannon imageclass D320 may have gotten too cold, do you think that would cause it to display...
(More)
My cannon imageclass D320 may have gotten too cold, do you think that would cause it to display E100? How do I fix it?
i keep getting a fault/error 042-326.
i bought a new itb belt but don't know how to change it. Can...
(More)
i bought a new itb belt but don't know how to change it. Can you help me?
