Question about InFocus Proxima UltraLight LX1 Multimedia Projector
Wobbly screen image
Thanks to ebackhus for the "screen door" feedback, but I'm not sure that's the issue. My grid has a wobbly or rippled quality to it. The guy I bought it from said it was a phase problem.
  • 3 Answers
Are you connected to a PC (DIGITAL SIGNAL)or a video source?
If you are getting a jumpy screen from a digital source like a LATTOP/PC you many be feeding a signal that's not equal to the resolution of the projector itself.l There is circuitry in the projector to attempt to convert the resolution of the picture received into the screen resolution. It's an imperfect process, especially if you have a higher screen resolution going in than the 1024 x 768 native resolution of thie LX-1.
What you need to do is set the video output of the computer to that resolution.
The original LX-1 Infocus units had a less capable resolution resolving circuit than their later units.
In a portable, it's possible to setup two resolutions - one for the Laptops own screen resolution and another for the auxilliary (external) resolution of a secondary display or a projector attached there. Modern Laptops usually have a resolution of 1400 x 800 pixels or higher (mine are 1920x 1200), The LX1 can not handle that resolution well at all. If you set the external output to something slightly higher like 1200x800 it will handle it better, but you still will have problems, especially on the older units from Norway.
(I seem to remember some control over phasing in the LX-1 setup, too. but this might be more applicable to a video input rather than a digital one.)
Posted on Apr 18, 2010
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Takes pictures but you cannot see image in lcd screen
This model only lets you see the image in certain modes. Test if it is properly working by changing the image mode to "P" and pressing the "Set" button (its in the middle of the arrow keys if you're having difficulty finding it. That should display the image on the LCD screen.
If that doesn't display an image, press "Menu" (upper left hand corner) and press the right arrow 4 times to get to the wrench with two dots menu (says "LCD brightness" on the first line. Press down 5 times and select Live view function settings and press "Set". Make sure the first line is set to enable. This should resolve the issue.
Please leave feedback if this was helpful, thanks.
Apr 18, 2011 | Canon EOS Rebel XSi Digital Camera
How do i clean a printhead?
When print heads get clogged, image quality suffers. But cleaning print heads is a quick and simple process. Here's a step-by-step tutorial on cleaning print heads. This is how i did it with my Canon Pixma MP530 but most printers will work in much the same way.
1. Click the Start button at the lower left corner of your screen.
2. Click on Control Panel. Next, choose Printers and Other Hardware, and then View Installed Printers or Fax Printers.
3. When the Printer page opens, right click on your printer's name, and choose Printing Preferences.
4. For the Pixma MP530, the Printing Preferences has five tabs across the top; choose Maintenance. Again, most printers should have a very similar set of options
5. The first button is for cleaning the print heads. You'll have to choose which print heads you want to clean (the Pixma inkjet has five cartridges). The best bet is to choose All Colors.
6. Make sure the printer is turned on and that there's some paper loaded, then click on Execute
7. The printer will print out a pattern with a grid along the top and six bars of different colors. Two images will display on your monitor that you can compare to the printed image. In one, the grid and colors are sharp and clear; in the other, some of the grid boxes are missing and the colors are striped.
8. If the printout matches the sharp, clear image, simply click Exit and you're done
9. If the printout has missing grid boxes or stripes, then click Cleaning. Once that's done, you'll repeat the whole process so you can ensure the cleaning was completely successful. It may take two cleanings if your print heads are really clogged
10. If, after two cleanings, you're still getting a poor result, there's a Deep Cleaning option on the Maintenance tab that should do the job.
I hope this information will be helpful. Thank you for using FixYa!
Your Feedback is greatly appreciated.
Feb 25, 2011 | HP Office Equipment & Supplies
Images are Suffering From Artifacting & Discolored Pixels
Do you have the sharpening turned up too high? Why not try a camera reset? Go into the menu and scroll to "reset" and follow the on-screen instructions.
Nov 27, 2009 | Nikon D60 Digital Camera
Alternator Feedback through speakers
What kind of feed back ? Does it get louder with RPM . Ignition system can also cause this . But just to be sure have the alternator check for ac voltage ripple .
Ripple voltage is when the DC voltage varies between (for example)12.5 Volts and 13.5 Volts, and does so rapidly. Technically, an alternator produces "alternating current", (hence the name, 'Alternator') and that AC voltage is converted to DC by running the current through a bank of "diodes". Alternator Diode Check and AC Ripple Check
Oct 05, 2017 | 2002 GMC Sierra 1500
Image looks like it has graph paper in the background
If it looks like a VERY tiny grid then that's an effect called "screen door." It tends to mainly plague LCD-type projectors and is a bit evident with DLP-type projectors. Unfortunately there is no fix for this issue.
Jun 03, 2008 | InFocus Proxima UltraLight LX1 Multimedia...
Metal grid came off
It sounds like the Main Charge Grid. If you are able to take it out of your machine then the grid probably broke off.
Is the grid a thin shiny metal piece about 10" long by about 1/2" wide?
Does it have a bunch of lines/open spaces on it.
If this is what i am describing, then you can purchase another drum unit, and this should take care of your problem with the copy quality and you will not have to worry about the grid.
Just to be on the safe side, where ever you place your order for a new drum unit, ask the company if the Main Charge Corona and grid come with the unit. I am pretty sure that model does have everything all in one unit.
Good luck.
Hope this helps. Please remember to post a feedback and rating if I have helped you in anyway.
Mac =)
Feb 25, 2008 | Sharp AL-1642CS Copier
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
Samsung LE32R87B
The fact that this is on all inputs suggests that teh screen is faulty, i would bring it back and get it replaced.
May 09, 2007 | Samsung LN-R409D 40 in. LCD Television
FD-71 and Printing
I have heard that 300 image dots per inch guarantees photo quality but in reality most people are happy with half that. So, a 150 image dots per printed inch would give you a print size of 4"x3".
Sep 13, 2005 | Sony Mavica MVC-FD71 Digital Camera
InFocus Proxima UltraLight LX1 Multimedia Projector Logo
253 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
