Need a replacement power cord for lcd 2000 falt screen
Iam in need of a replacement power cord for a Polairod LCD 2000 .
I have checked best buy (which is the store from which I purchased ) and Curit City they sate that they do not have one and they do not know what power cord can be used as a replacement .
Thank You for your assistance
Octavia Edinburg
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey Okky,
If you have been having difficulty locating a replacement power cord for your Polaroid LCD-2000 TV, I would strongly suggest contacting Polaroid directly for further assistance. In some cases, if a manufacturer is unable to provide you with an original equipment manufacturer (OEM) part, they may be able to provide you with a number of aftermarket part models that may better fit your needs.
Additionally, please keep in mind that while Best Buy™ stores may not always carry replacement parts for every product we sell, our online partner's website typically will have an expanded assortment of replacement parts available.
You should be able to reach Polaroid by calling their toll-free hotline at (866)-289-5168, or you can always visit Best Buy Partsearch using the link I've provided below:
http://bestbuy.partsearch.com/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 06, 2008
Falt screen tv has a white screen when I turn it on,audio ok,picture comes on after about 20 minutes,any ideas?
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 18, 2012 | LG Electronics 42IN WS LCD 1920X1080...
No power
Got no power on my tv need sone advice as change fuse still not working
Sep 07, 2011 | Sansui HDLCD3200 TV
I have a 32lc7d tv and i cant get it to turn on all the time. the on light will be green but no sound or picture. the light also blinks about 15 times before going to a solid green color. the tv will...
This problems ur tv are having are only can be causes by two boards,the tv power supply board or the tv Tuner signal board.The tv power supply board that the board where the power a/c cord plug into it.The tv Tuner signal board that the board where the incomming broadcasting signal wire plug into it.This problems very easy to fix.If it is the tv power supply board is the causes,because u can check the tv power supply board carefully u will find dying capacitors parts that will bulging up or puffing up on to it tops.U have all the tools and know basic electronic just replaced all the dying capactors for all new capcitors parts same micro ferit but the capacitors voltages like 5 or 10 voltages higher for better heat resistance for the life of the tv power supply board.If it is the tv Tuner signal board,very hard fix and determine where the dying parts are in this board,because this board is cover with many ICS chips on this board.If the tv the Tuner signal board is the problems best just buy the whole refurbish tv Tuner signal board for the replacement.Or u can tries websites like Shopjimmy.com,Ebay.com to buy the whole refurbish tv power supply board too,if u don't know how to or have all the tools to replaced those dying capacitors parts and also can buy the whole refurbish tv Tuner signal in these two websites too.
Apr 16, 2011 | LG 32LC7D Television
I turn on my olympus stylus 600 camera and all i get it a black screen.
You need to check whether the LCD screen is damaged or not. The best way to do this is shoot a picture, and then down load to PC. Check whether the picture is ok or not. If the picture is ok, then LCD is bad. You need to replace your LCD.
If you wan tto do it yourself, the following are some sites for help:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
Buy a used camera (one sold for parts) through ebay.com very cheap. Buy a jewellers screwdriver set for $1 from Dollar store. Then replace the LCD.
Jan 18, 2011 | Olympus Stylus 600 Digital Camera
I need a power cord for a balance CM2019 lcd monitor
You can buy a power cord at any Lowes, Home Depot, Radio Shack or Best Buy. The power cord is not unique to the monitor.
Hope it guides you :)
Jul 14, 2010 | Balance CM2019 19" LCD Monitor
My viewsonic lost a cap no 1000uf @ 16volt after replacing that cap the screen came back on but know has a half screen and on the other side there are about 50 colored lines that are vertical from top to...
You can have the a LCD controller (circuit board on the LCD panel where the flat connector from the digital/controller board is connected to) failure or the falt connector came loose. Check that out first.
Feb 24, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
Feb 06, 2009 | Niko OTP-2613W 26 in. LCD Television
Need a power cord for a Zenith L20V26C 20.1 in. LCD Television
You can find a replacement power cord for this model from a major Zenith/LG parts distributor at the following link:
Zenith/LG L20V26C Replacement Part Power Cord
Please note the AC Adapter is no longer available from the manufacturer as you can see here.
Jan 29, 2009 | Zenith L20V26C 20.1 in. LCD Television
I need a power cord for a mag innovision lcd monitor
Dec 26, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Pltv32
i have seen some replacements on ebay
1 @ $25
and another @ $124
search with brand or model #
Nov 15, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Televison & Video Logo
228 people viewed this question
Top Televison & Video Experts
Electro Med Services...
