Question about Intel Motherboard
Wont boot I have installed a ECS 945p-a v1.1 motherboard and a 3.2 gig celeron D processor, trying to build myself a computer. When I boot the computer it gives me a message saying CMOS is invalid 0085 or overclocking failed, one of the 2 messages showes up and wont let me go any further. I have replaced the batt. and it did not fix the problem. Also when i push F! and change the settings I push F10 to save and exit the computer restarts back to the settings befor i changed them.
  • 5 more comments
  • irap Jun 05, 2008
    I also reset the mother board no change.
  • irap Jun 05, 2008
    It is a Rhycom 550 watt
  • irap Jun 05, 2008
    I tried to restore system defaults but no change in outcome.
  • irap Jun 05, 2008
    Is it possable that even though it is new the board might be bad??
  • irap Jun 05, 2008
    My power supply is new, I do not have a floppy, and at this point i will try anything.
  • irap Jun 05, 2008
    This worked,
    1. With just a USB keyboard, VGA monitor and power plugged, power on
    the computer and enter the BIOS when prompt (after the 'date not set'
    message). Once in, just exit and SAVE settings. I mention save because
    using the 'discard settings' caused the system to be inoperable and
    requires the CMOS to be cleared.
    2. After exiting BIOS, the pc should restart. During this period,
    unplug the keyboard. Now, watch the screen and see if the pc bypasses
    the the "CMOS checksum bad", "Over-clocking failed !!!" and the message
    to enter setup. Right after those lines, a new message along the lines
    of "NVRam...." will appear and it will proceed to boot, only to stop
    due to no bootable device. Insert a Windows cd and power off (and
    unplug) the pc and clear the CMOS.
    3. Now, power on the computer and follow the procedure in step 2 with
    the keyboard. After the "NV...." message, the pc should begin to boot
    into the Windows installation. I recommend to partition the HD to 5gb
    and quick format in NTFS to reduce time waste, since this will just be
    a temporary install. After the Windows install restarts the pc, power
    down the pc and clear the CMOS again. Turn on the PC as in step 2 and
    continue the install, with every restart acompanied by the clearing of
    the CMOS.
    4. After Windows is installed and you are able to boot into Windows,
    update the motherboard's firmware in Windows according to ECS'
    instruction. I recommend burning the bios and flashing program from
    another pc to transfer to the ECS machine. After the reflash, restart
    the computer. This time, leave the keyboard plugged. The pc should now
    boot up without error. If an error occurs, clear the CMOS and try
    again. It should be working now.
    Well, that should be most of the information there. Reading it may be
    difficult since I jumped around inputing the steps and each step isn't
    exactly a one liner command. Hopefully this helps. Maybe when the sale
    comes again, you can try this out and get it to work.
  • Larry Miller May 11, 2010
    Check your last post about this board, and tell me the info about your power supply, please, then we can go from there to fix this problem.
  • 99 Answers
It is very possible that it is a bad board....ive seen some bad ECS boards before
or, perhaps flashing the BIOS might help this problem, although that procedure, if done wrong, can leave it in as bad a state as you are in right now...
if you are interested in doing this, let me know and i'll get the instructions for you...do you have a floppy drive in your computer?
Posted on Jun 05, 2008
  • 2 more comments
  • Larry Miller Jun 05, 2008
    or, just buy another board...also, is your power supply a new, or used one??
    is your memory seated properly (has it clicked on both ends...check it again)...is your CPU seated properly...check all connections everywhere....but i got a feeling the board may be to blame..is it new or used...or where did you buy it?
    another hunch...be sure to check the small square power connection that goes onto the board in addition to the main power connection....
    also...what are the specs on the memory your using?....
    Heres a page from the ECS website concerning a bios flash for your board, which, given everything thats been said so far,is a viable possibility in making your MB work...
    http://www.ecsusa.com/ECSWebSite/Product...
    is your CPU new?...did you apply the proper heatsink goo (thermal paste) when you assembled it?
  • 121 Answers
Try to restore system defaults in bios setup and exit saving changes.
I had an intel d865 perl motherboard with a 2.8 processor and 4 gigs of ram, computeer ran great for years then one day i shorted the motehrboard and fried it, i ordered a brand new one and installed it...
Thanks for asking FixYa for help. My name is Jeff and I will be assisting you today.
If you are using the same motherboard as the first one, what you are experiencing is too weird to worry over. Is it still under warranty? I'd say you have proved that the MB is deffective. Take it back for a refund or exchange.
If you are in need of additional help, please let us know.
Thank you for allowing us to help you today.
Jan 19, 2011 | Intel D865PERL Motherboard
Compatibility Intel Celeron 2.66, ECS Elitegroup P4M800PRO-M3,
what is your motherboard name and version, send me your total computer quoation on my email address below...
shafqatullah85@live.com
good luck
shafky
Apr 12, 2009 | Intel Celeron, 2.6 GHz...
Ecs 945p-a install hdd sata
Choose in bios the setting about HDD. Choose Enhanced Sata compatibility. Now you can plug4 satas
Sep 23, 2008 | ECS 945P-A (V3.0) Motherboard
Everything works, but no display
Try a different stick of RAM. Like a smaller amount. try 512MB and see what happens. if 512 works, try the 1 of the 1GB sticks so you can still have atleast have 1GB.
Jun 11, 2008 | ECS 945P-A (V3.0) Motherboard
Cmos
have you tried resetting the MB. there is usually a jumber that you move in order to reset the settings.
Jun 05, 2008 | Intel Motherboard
CMOS checksum bad 0085
the problem might lie in the fact that the mother board and cpu cannot be handled at the speed
or it requires the jumpers to be set by so that the cpu can be clocked properly if you got a mother board spec guide follow the guide for *********** board to set up 3.2
you might also have to set the bios to the cpu speed cause if mother board doesnt do jumpers no more the setting would be in bios
hit the delete key direct are power up this will take you to bios
its not the battery
Second opinion for ecs p4vmm2 8.1
It's ok to upgrade the processor to P4 the mother board is capable to run the pentium 4 2.0Ghz only . I said that because i'm using that type of motherboard ecs p4vmm2 with processor 2.0Ghz. But for my opinion the problem of your friend computer is not the processor is about the cooling fan heatsink because if the heatsink is not fit or properly lock the processor is over heating that's why the computer hanging and shutdown. If you can tight the two clip that was broken the problem is solved because i have also the same problem before one of my client computer. but if you friend want to upgrade to p4 it's better to buy also a new fan and heatsink for P4.
Thanks and God Bless
Jemuel
May 08, 2008 | EliteGroup P4VMM2 Motherboard
Intel Motherboard Logo
66 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
