Question about Motorola Mobility RAZR V3
Texting problems i can not text in one letter mode, only has multiple letter options please help
  • 94 Answers
When u go into write mess then press upper butten or from ur # key u can change mode of writing put it 2 multi tap then u will be able 2 write single letter from ur key pad. reply me
Posted on Jun 05, 2008
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Texting configuration gone wrong please help!
I have the same problem on my KP501, SOMEONE PLEASE ANSWERRR :( x
Jun 29, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    When trying to text incorrect letters appear
    There should be an option somewhere when you are in the message menu on how to switch from the text mode that tries to finish your words for you to the text mode where you have to push the button however many times to get the the single letter you want. Although if you are in the auto finish mode you can simply ignore what it's suggesting and continue spelling out the word yourself if you want. example: hit 9 6 8 one time each to spell the word "you"..buy if your trying to be able to short hand text like "thk u" your gonna have to look around in your text mode settings.
    Jan 02, 2009 | Nokia 6126 Cellular Phone
    Predictive text problems with my samsung u900
    when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
    rate me please thanks
    Oct 04, 2008 | Samsung U900 Soul Cellular Phone
    KU990
    hi,
    in this mobile, there is an option in message settings, where you need to change the default option selected as send multiple messages as mms to send them as multiple sms's. then it will be normal.
    Jul 18, 2008 | LG KU990 Viewty
    Can't get the all caps off when texting
    I had the same problem on my Motorola C139 TRACFONE, and I just figured it out. When you type a letter, quickly hit the "0+↑" button. If you don't do if fast enough it will register as a +. But if you do it quickly it will change the case of the letter typed. To put it back just type the next letter and quickly hit the "0+↑" button again and it will change it back. hope this helps TW
    Feb 26, 2008 | Motorola Mobility TracFone C139-4 Cellular...
    Motorola Mobility RAZR V3 Logo
    100 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
