Question about Toshiba Computers & Internet
Have a replacement kb K000026590 a Tosh Sat M65-E821 (PSM60U-0CR021). I have no instructions as to how to be the top of the the case off - short of jimmying w/ an sdrvr. Help pleaaase!
  • 79 Answers
Hi this is how it is done in a HP laptop
i hope it helps you out
Remove the keyboard
  1. Loosen the four captive P1 Phillips-head screws that secure the keyboard to the base enclosure.
  2. Turn the notebook right side up and open the display panel fully.
  3. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  4. Using minimal force, lift the locking bar to unlock the pointing stick ZIF connector on the system board (only on models with a pointing stick). CAUTION: Use care to prevent damaging the ZIF connector and ribbon cable.
  5. Remove the pointing stick ribbon cable from the ZIF connector.
  6. Using minimal force, flip the locking bar up to unlock the keyboard ZIF connector on the system board.
All the best
AJ
Posted on Jun 05, 2008
  • Abhishek Jha Jun 05, 2008
    you can also see a video in this link
    http://h20000.www2.hp.com/bizsupport/Tec...
E821 error code in canon IR 6570 ?
error code relative to the clogging of toner inside the waste toner auger tube. this will require a technician.
Feb 17, 2015 | Canon Office Equipment & Supplies
Keyboard replacement
Do you have a manual for this laptop? If not, let's find you one.
Jun 06, 2008 | Toshiba Satellite M65-S821 Notebook
Jumper
change the position of ur jumper accordingly as instructed above the hard disk case
Jun 22, 2013 | Dell Precision M65 Notebook
Im have trouble ir 5570 code eror e821
hallooo ... sp,
what's the difference with the IR5570 IR 6570 .. thanks
Nov 30, 2010 | Canon imageRUNNER 5570 Copier
Dell Precision M65 Locked
There is usually only one true way to clear this type of password...the only problem with some of these systems is the password is stored in a chip on the the motherboard and not in the RTC battery, but this may not be the case with this particular model. Below is the procedure for the "shorting" of the RTC battery leads.
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Only reboot with the AC adapter plugged in, not the main laptop battery. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
If the battery is the disc type and sits in a horizontal socket on the motherboard, then it is a little more difficult to perform but the theory is still good, the positive and negative have to be shorted and the same procedure done. In most cases, just removing the cmos battery does not work in laptops, this is because there is extra security needed because of their portability.
Jan 17, 2010 | Dell Precision M65 Notebook
Changed from vista to xp camera doesn't work on tosh sat pro s300
1. uninstall the camera driver
2. download updated XP driver for ur camera
3. install new XP driver
Dec 28, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba M65-9062 Turns on but won't boot up.
Go here: http://www.notebookforums.com/thread200970.html
This may solve your problem without replacing the MB.
Mar 31, 2009 | Toshiba Satellite M65-S9062: M65-S9062...
Broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Jun 28, 2008 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
    Computers & Internet Logo
    128 people viewed this question
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
