Question about Sony Cyber-Shot DSC-F828 Digital Camera
Random "mode flipping"
At random times while using the camera, the setting of the camera will randomly "flip" as if I was rotating the mode dial. On a number of occasions, the camera has settled on "play" mode and has to be turned off before it will be able to take pictures again. I have a 1 gig compact flash, but no memory stick. Is there anything I can do to try and fix this. The camera is more than a few years old and is owned by the DOC in Arizona.
  • 2 more comments
  • ADC Post Jun 06, 2008
    One drop where? Through top of dial, between dial and indicator or through side of dial near the bottom? Also, what will this do. The dial already moves smoothly. Thank you
  • mspetter Jun 14, 2008
    Help! I have the same problem. My camera was in and out of repairs for the past six months. Nothing was fixed.
  • johnnymack12 Jul 24, 2008
    I have the same problem with my 4 year old F828. Did the wd-40 trick work? If so where did u place the lubricant, and did you have to disassemble any pieces?
  • Anonymous Apr 17, 2009
    where do i place the lubricant and do i have to dissemble it?
  • 10,594 Answers
Mode dial has connection problem in built-in switch. try to use W-40 lubricant 1 drop.
Posted on Jun 05, 2008
Bosch AXT 2200 HP shredder motor turns the wrong way
Try flipping the plug on the wall plug it in c which way the unplug rotate an plug it in again I no when working with. Motor proper polarity determined direction
May 21, 2014 | Bosch AXT 22 D Electric Drum Garden...
Use RAN# button to gnerate random numbers
The RAN# button generates a random number between 0 and 1.If you want to flip a coin, see whether the generated random number is less than 0.5. Alternatively, multiply by 2 and see whether the integer portion is 0 or 1.If you want to flip a die, multiply the generated random number by 6, add 1, and ignore the fractional portion. This will give you a number in the range 1 through 6. A similar method will allow you to generate random numbers in any range.
Apr 16, 2012 | Casio FX-55 Calculator
Is the day of the week in the middle of dau or night or at the beginning it on the GE vacation timer?
Vacation timers turn lights on-and-off at random times.
Timer dial rotates clockwise. Notice small arrows on timer dial located below each day letter.
Each day starts at the letter.
When the time-now pointer is at W, then wednesday starts.
For example W is wednesday. And th is thursday. The hours that show between W and th are wednesday hours.
Open following image. The time now pointer is pointed at 4:00pm Wednesday.
The blue letters with white background are AM, and white letters with blue background are PM.
To set current time, rotate dial clockwise until current time lines up with time-now pointer.
Time-now pointer is stationary.
Open following link to see how to set timers by experimenting with features.
Add a comment for more free help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 19, 2011 | GE 50462 7Day Random Vacation Timer
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
Have model TE02DHB/TE22DHB. Setting random mode but I do not see any "RND" on screen after following directions for random mode.
Timer has to be programmed first with on and off times.
Manual says press FUNCTION and RND digits 'flash' on display
Then press set button
Then RND will appear on display.
Timer then uses your programmed on-off times, and randomly varies programmed on-off times in range from 2 to 30 minutes.
So if regular program says ON at 7, then random will vary ON time from 6:30 to 7:30, assuming timer functions as shown in manual and timer is not defective.
If above information does not work, then use circuit analyzer and check polarity of outlet.
Jul 18, 2011 | Hardware & Accessories
Is there a way to put the device on shuffle mode?
  • There is a random setting rather than a shuffle mode. Same thing just a different name.
  • While in the play mode menu press "PREV/NEXT" to select the desired repeat mode ie.
  • Normal, Repeat One, Repeat All, Random, Random All, Preview.
  • You want to choose "Random" or Random All" depending on
  • Random - All music is played randomly until all songs have been heard.
  • Random All - All music will play randomly until you turn the MP3 player off.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Curtis MPS2015 MP3 Player
Preview results in random croppings, rotations, and added pics
Hi I'm having a similar problem and haven't managed to fix it. Have you solved it? Thanks Martin
Mar 07, 2010 | Epson Perfection 4990 Flatbed Scanner
How to use the random number generator on the calculator.
To access the Random number generator, press [MENU], Use arrows to select [RUN] and press [EXE].
In [RUN] press [OPTN][F6:->] to pan to the right then press [F3:PROB] then [F4:RAND#]. The command echoes on the screen.
  1. Now if you press [EXE] a number between 0 and 1 is generated.
  2. Each time you press [EXE] a new number is generated.
Although it is not documented, I found out that if you enter RAND#(n) where n is an integer, it generates a number between (0 and n)
Hope it helps.
Nov 07, 2009 | Casio FX-9750GPlus Calculator
What is the code to enter for random play and/or background mode?
If it isn't a very early OMT then there is a switch on the right of the Credit Computer which says Continuous Play on it. Flip the switch and the machine will play random selections.
Oct 08, 2009 | Wurlitzer Jukebox 1015 One More Time...
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Sony Cyber-Shot DSC-F828 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
