Question about Whirlpool GEW9200L Electric Dryer
MY CONTROLS ARE LOCKED
I have a whirlpool duet dryer model GEW9200LWO IT HAS STOPPED WORKING , NO ERROR CODE JUST DISPLAYS ON THE LEFT HAND SIDE OF MACHINE THAT CONTROLS LOCK.........DOES ANYONE HAVE ANY IDEA WHAT IS GOING ON ?
  • PUNISHER65 Jun 05, 2008
    OK , BUT WHICH KEY ? TRIED CONTROL KEY AND NOT WORKING......ANYTHING ELSE
    I TRIED WHAT U SAID AND STILL HAVE THE RED LIGHT AT THE CONTROL LOCK........ANYTHING ELSE TO TRY
Press and hold the End of Cycle button for 3 seconds.
Posted on Nov 06, 2008
Hold down the end of cycle button for 3-5 seconds...worked for me!
Posted on Nov 16, 2008
Where can I find a list of error codes for the Duet Gas Dryer?
Posted on Jul 07, 2008
  • 868 Answers
Hold down the key to un lock pad for 3-5 seconds.Please leave a Rating! Thanx!
Posted on Jun 05, 2008
Duet model GEW9200L. What does code 08 indicate?
there is no such error code on this dryer, that is likely the time left on the display... If the dryer stopped at the 8 minute mark with no error, check the door switch because it can interrupt a cycle, but will result in no error... Did you try to start it again, what happened? Whirlpool Dryer Main Control Board WP8546219
Jan 15, 2016 | Whirlpool Dryers
My duet whirlpool washer has stop working. The control lock light is on. so what do I do from here
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer stuck on control lock mode
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet Dryer Lockout function stuck
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Model GEW9200LWO control lock light
Even tho the door lock light is working the switch has dropped a leg supplying power to the rest of the machine. Repace the door switch and you should be good to go. Even tho you have a GE it was made by frigidaire for GE. Common problem with the newer switches. They have gone back to the originals as the replacement for this.
Feb 01, 2010 | Whirlpool ET8CHEXSQ Dryer
I have a whirlpool duet washer. It worked fine
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%^^%%
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Whirlpool duet control locked
Whirlpool GHW946PLO locked controls light is on and will not respond. Have tried to unplug to reset default codes.
Jul 09, 2008 | Dryers
Whirlpool GEW9200L Electric Dryer Logo
402 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
