RICOH 1045 P
  • 1,326 Answers
There is not a waste toner bottle.... The used or waste toner is stored in the tranfer bealt unit on the right side door to remove a paper jam. It needs to be removed from the door by a gray lever that is toward the front of the copier . Move it to the right and remove the whole unit. You need to get the bealt off with removing 2 screws and 1 spring and the tension is released then remove the bealt and remove the 6 screws that hold the cover on and proceed to vacum out all the toner under the plate and make sure you get all of the toner in the corners as well. Then put the unit back togather and reinstall it and turn the copy "ON" and worry about next year... Good Luck
Posted on Jun 06, 2008
Fix an error message on the Ricoh Aficio 1224c that says 'used toner bottle full'? We have emptied the used toner bottle but the error message persists. What is the best way to fix this?
Check the waste bottle to see if there is a chip mounted on it somewhere. If not see if there is an optical sensor or clear window. If there is a chip it will need to be replaced or a new unit used. If there is a window or optical sensor you should be able to remove it, clean it out, and replace it. These are often the last part to fill with toner and create a light path block.
Feb 06, 2015 | Ricoh Office Equipment & Supplies
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Pls we need your help with ricoh affico printer 3224C the screen of it write this message : used toner bottle setting error used toner bottle -2 is not set properly. open the part as shown and set the...
look my friend used toner means that this toner is disposal or exhausted ok ensure that empty exhausted toner not mean fresh toner are yo ander stand
Jan 12, 2011 | Ricoh Aficio 1035 Copier
How do i change the toner colection bottle for a Ricoh aficio 350 copier?
There is no toner collection bottle for the 350, used toner is stored in the transfer belt unit. It must be pulled from the machine disassembled then empty used toner reassemble and put back in machine, a counter must also be reset, cant remember which sp code this is though.
Sep 16, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh copier imagio error used toner bottle is full
Change the used toner botle,desasembly the LCT tray,open the front cover and change the waste toner bottle.
Feb 09, 2010 | Ricoh Aficio 450 Copier
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Ricoh 1018d won't add toner after installing toner bottle.
the part numbers are different for each toner from ricoh, Lanier, Savin and Gestetner. From what I recall is the bottles are different, check the old bottle vs new. Also if the machine had run very low you may have to open and close the fron cover several times, this intiates a toner feed program.
Feb 26, 2008 | Ricoh Aficio 1018D All-In-One Laser...
243 people viewed this question
