Question about Kenmore Oasis HE 27082 Top Load Washer
Washer beeping during washing - no code error - now it starts and with the lid open
Bought the washer August 4, 2006 - out of warranty - when you turn it on it goes to clean washer no matter what buttons you push - no error codes coming up on it - and last night I woke up to find it running with the lid open on the unit - unpluged it and went back to bed - my wife plugged it back in this morning and it starts running water and stops as it pleases with the lid open or closed - any suggestions other than throwing it out the door!
thanks
Rodney I have an Oasis model 110 27062600. Mine has started beeping continuously around the clock--even when there are no clothes in the washer and it will start this by itself. I haven't experienced the washer washing by itself--yet. However, I am unable to change any of the options (water temp, etc). I have to mash the start button over and over before it will take. I have read all the solutions and they are tremendously helpful (so glad I looked here before I called Sears!) but I am still confused as to what I need. Can someone tell me with the part numbers, please? Thank you for your help!
  • 3,037 Answers
Basically your user interface has gone bad and will cost around $100 to replace. Sears will be able to send you a new one or you can try finding a new one on websites online.
It is something that you can do yourself and if you have any more questions on this, let me know and I would be glad to help you out.
good luck
Posted on Jun 05, 2008
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Genius:
  • 1,665 Answers
Have alook at troublshooting on link below
http://www.repairclinic.com/0088_11_1.asp
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Jun 05, 2008
    The problem is caused by the User Interface board which is located behind the control panel.
    Make sure you identify the correct board.
    There is a Main Control board located UNDER the console.
    The user interface board is located BEHIND the console where the control knob and push buttons are.
    The only fix for this problem is to replace the control board in the control panel.
Model 11026955690. Why does screen indicate LP?
I am not familiar with any error code referencing "LP". Could you be seeing "LF"?
Below are the error codes listed for your washer:
  • "LF" (Long Fill) Inlet hoses are kinked or clogged or water valve screens are not clear. (Solution: Straighten inlet hoses or clear screens of any foreign material.)
  • "LD" (Long Drain) Drain hose is kinked or clogged. (Solution: Straighten or unclog hose.)
  • "FF" (Fill Failure) Problem with water level sensing system. (Solution: Call for service.)
  • "OL" (Open Lid) Lid Is open during drain or spin. (Solution: Close lid.)
  • "PF" (Power Failure) Power to washer went off during cycle. (Solution: Press any pad to clear the display. Restart the washer from the beginning of the cycle.)
Source: Kenmore 11026955690 Manual
Aug 25, 2015 | Kenmore Washing Machines
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Apr 30, 2009 | Washing Machines
Beeping
stuck key or bad control
Nov 09, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he beeping during cycle
"HC" indicates hot and cold hoses switched.
Aug 23, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
There has been a noted problem with the Oasis and the particular problem(s) you just described. The problem is caused by the User Interface board which is located behind the control panel. Make sure you identify the correct board. There is a Main Control board located UNDER the console. The user interface board is located BEHIND the console where the control knob and push buttons are. The only fix for this problem is to replace the control board in the control panel. If you provide me with your model number (located around the wash tub opening under the lid somewhere), I will research a part number and price for you. I can also give you step-by-step instructions on how to repair it yourself. Post back with comments and let me know. I hope this helps you.
Nov 12, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
