Question about Toshiba Satellite P105-S9722 Notebook
Toshiba satellite p200 laptop display problem
I am getting red lines across the display.
The problem is intermittent and looks to all intents as though the resolution of the screen has dropped.
I believe the problem may be a loose connection on the display.
I believe it is easy to resolve, but I need to know how to open up the display panel.
There are four sticky nubs covering the screws.
What do I need to do when I have removed these?
Thanks
Warm Regards
David
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Mite be your screen card but first this is how you open the screen ,there are two square or round tabs covering screws that you need to peel off with something with a point on it 2 on the top and two or four on the bottom ,peel them loose and then unscrew the screws and then there is little tabs around the inside around the cover gently insert a flait screw driver to use as a pry bar type
once you have one section loose it should come off pretty simple
depends on type of toshiba you have there mite be a couple of screws on the bottom under battery or on the bottom of the board
you must gently pull that plastic cover or it will crack ,
after you have taken it loose you will see the hinges and the screen card it is a two small plug white with two wires usally
pink white or black and white see if it is loose if not mite check the back connection on the screen ,but to do that you have two
unscrew small screws on the side of the screen or and the hinge screws if niether is loose i would unhook screen and try plugging in a orther screen and see if it boots up normal if that is so i suggest that your screen card has taken a dump and mite need to order a new one or it mite be the screen it self .....la la linda
if you need more help ask me I will try to help you ...
Posted on Jun 05, 2008
    Genius:
  • 3,422 Answers
HI,
Please CLICK HERE
Everything is mentioned step by step with the diagrams which will tell you what you'll have to do after removing the screws.
Goodluck,
Please don't forget to rate or accept the solution
  • 3,037 Answers
Yes, just sounds like a loose connection. After taking off all of the screws, you need to pry the outer panel off and then just push in the connection for the screen. It will be attached to a thin/wide wire membrane and you just need to make sure all connections are secure and clean. You can pry off the outer panels gently with a fingernail or with a flatheaded screwdriver. You may notice some thread locker on the screws which is normal.
If you have more questions or run into any problems, please let me know
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Genius:
  • 1,447 Answers
Hi-
Before opening it let me ask first if your laptop is still within the warranty period from the store or from toshiba? LCD is actually attach by some wires to the mainboard, opening this up might be too risky.
keep me posted, thanks!!
    Genius:
  • 1,665 Answers
Have a look for user manual at
http://www.ideal.gr/index.php?id=298&Itemid=271
I have a Toshiba Satellite Pavilion P200 laptop. I recently purchased a replacement battery however the replacement will only charge to 99%. Any suggestions please?
New recharageable batteries need to be charged overnight and fully discharged several times before they reach their full charge capacity.
Mar 14, 2012 | Toshiba Satellite P200-0TD00Y Notebook
Does my toshiba P200 have a sound card which
Yes, the Toshiba Satellite P200 does have a sound card.
Your laptop should have both headphone and microphone audio jacks on its outer edge somewhere.
Apr 30, 2010 | Toshiba Computers & Internet
BSoD on Toshiba Satellite P200-16B
you can look up the stop error for 0×0000007E at this site:
http://aumha.org/a/stop.htm
There are several MSDN articles for this issue
Jan 20, 2010 | Toshiba Satellite A85-S107 Notebook
Toshiba P200-1ee Screen fault
Hello, I have a Toshiba Satellite P200-rt2 that has the same issue. They told me that there's a part that connects to the monitor that needs to be replaced. It costs as much as the computer does. So, I have bought a new one. I want to know if there are other people with this issue. Maybe we can go to Toshiba with this issue.
Oct 21, 2009 | Toshiba Satellite P200-0TD00Y Notebook
Intermittant red raster
Is it under warranty?
I'd call Toshiba and let them try some stuff with ya over the phone - chances are you have a loose connection to your display, or the display itself may be pooping out on you.
Jun 15, 2009 | Toshiba Satellite P205-S6337 Notebook
Battlefield 2?: Complete Collection
Satellite P200-1JV - Intel® Pentium® Dual-Core Processor T5450
- Genuine Windows® Vista® Home Premium Edition
- DVD Super Multi drive (Double Layer)
- 2,048 (1,024 + 1,024) MB
- 17.1 " Toshiba TruBrite® WXGA+ TFT display
Yes it will work easy, no dubt about that, Good luck
Dec 05, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba p200 no display
That is not typical ,, If me. I would return it to place of purchase and get another one ,
best of luck
Nov 16, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite P105-S9722 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
