Question about NEC-Mitsubishi Nec Display Solutions Accusync AS700 (White) 17 in.CRT Conventional Monitor
The resistor R304 is blown out on a NEC AS70 chassis N9701
I just need the right value for this resistor, i can not read it because it is all burned.
Thank you
Burned resistors
I have the same problem with the Mighty Mig...Did you find these resistor values?
Jan 23, 2010 | Welding Tools
I have a Technics Stereo Integrated Amplifier SU-G75 That does not allow the Tuner, CD Player, Tape Deck work. I connected the components to a working Stereo and all work. The Stereo/Amp power up and the...
You can try replacing the resistors. They are available using part number: ERDS1FJ100 from tritronicsinc.com for $1.10 each. Typically though, the reason for the silence is a defective output amp-pac. This too can be purchased from tritronicsinc.com using part number: RSN3305-P for $65.73. This is the amp for the front speakers. The rear and center speaker5s use part number: SVI3205B which is listed as no longer available.
Hope this helps,
Dan
Nov 26, 2009 | Audio Players & Recorders
I Need values of resisters R-82 and R-85. They feed plus and minus voltage to power amps. amps shorted and burned resistors. The amp is a subwoofer amp in a B & W model DM605 s2 speaker. Any help would...
If the resistors were blown, the power amp which is either transistors or an amplifier package has been shorted out. The resistors are very low resistance, and used really as slow blowing fuse. The value is probably a fraction of an ohm (eg. point two ohms)
Aug 11, 2009 | Audio Players & Recorders
NEED TO KNOW THE OHMS VALUE FOR RESISTOR ON PEANUT 8685
I have the same problem, but it is open.  The color code Brown - Green - Brown - Gold.  If it is a resistor, the value must be 150 ohms +/- 5%.  To confirm the value, I open the working trimmer and remove one leg from the circuit and measure resistance.  The meter reads only 4 ohms.  Therefore, I think it is an inductor (150uH +/-5%), not resistor.
Jan 27, 2009 | Wahl 8685 Hair Trimmer
Burned resistor, need value for replacement
I re-drew the schematics from the PCB-layout and did some backward engineering to determine the resistor value. The machine is now again in excellent working order.
Jan 20, 2009 | Sewing Machines
Need value of resistors R7A4 and R753 in a Gateway VX700 monitor. Chassis family V8705. Board bears the codes CT920A2600 and CT920A2600. The resistors are physically located around the high tension...
long time since i worked on one of those chassis but if i remember right there both 250k ohm 1/2 Watt carbon in series
but its more common for them to go open circuit if there burned you better check out the rest of the circuit around the LOPT stage
Feb 28, 2008 | Computers & Internet
Need value of RL06
There is a service bulletin for this problem: Fixfinder Model: 19TVR60 Chassis: Circuit: Horizontal Part: CL05 Symptom: No Horizontal Deflection and RL06 is Burning. FOUND CL05 OPEN Solution: Replaced CL05. RL06 = 680 ohms 2 watt resistor CL05 = .39 UF 250 volt poly capacitor
Aug 29, 2007 | GE 19TVR60 19 in. Combo
NEC-Mitsubishi Nec Display Solutions Accusync AS700 (White) 17 in.CRT Conventional Monitor Logo
81 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
