Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Green line on each side of the plasma display.
Green and white line on the bottom half of the plasma display on each side.
  • gary1210 Aug 20, 2008
    I sent the TV for repairs and was told it was a $2700.00 repair on a set I paid a little less that $2500.00 for. I bought it from Kings in Owensboro, Ky. Got no help from them at all, and no help from Toshiba. I found my own solution to the problem. I went to Best Buy and replaced that Toshiba piece of junk with a Sony. I will never buy from Kings or Toshiba again. Lesson learned.
    There's a lot of problems with this Toshibe TV. Toshiba had problems with the laptop computers. Now there's many lawsuits. I keep watching the websites to see if there's any class action lawsuits on this tv set.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Posted on Aug 20, 2008
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
I have a samsung 52"
The whole screen or what is called the panel will need to be replaced. the panel comes with all the circuit boards less the power board and main board.
Aug 31, 2011 | Televison & Video
Tv has white horizontal lines across screen you can still see what ever your watching on the screen its just distorted becuase of the lines if i disconnect the 3 ribbon cables on the top y buffer i...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 15, 2017 | Philips 50PF9830A 50 in. Plasma HDTV
Lg plasma DT50py10. When turning on bottom half of screen is snowy and has lots of white lines for approx 20 min then it goes away. Top half of screen is normal
sounds like your bottom buffer board is on its way out .
Will also need to check the y sus board as this some times causes the buffers boards to fail.
May 24, 2011 | LG DU-50PX10 50 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
I got white vertical line running down a plasma display panel . they are close together that you cant even see on that side of the tv. on a closer inspection they are blue-green-red-blue-green-.... but...
A vertical line running down a plasma display can be caused by :
faulty buffer module.
Fauly sustain card.
Faulty plasma display.
Try unplugging power cable and see if this helps, if it does not , then you will need to call a technician.
In that case call the support number listed on your owner manual.
If warranty has expired, ask for a warranty extension, if available. this is cheaper than repair cost, and will cover the repair.
Jan 04, 2009 | Sony PFM-50C1 50 in. Plasma HDTV
Plasma display fault
nhjchabghchtybahbbyug
Mar 12, 2008 | Televison & Video
White line
There are individual drivers for each line of plasma cells in the display (horz. & vert.), but they usually are an integral part of the display module that can only be repaired by the manufacturer. A new 42" HD-ready set with more features can be bought for 50-75% of what was likely paid for this one. The cheapest thing to do is learn to live with it. (That's what I'd do until the set got worse or the prices got even lower.)
Apr 06, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
575 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
