Question about Acer Aspire 1640Z Notebook
Keyboard wont work
My friend just reformatted his acer 1640z laptop back to factory settings and the keyboard is not working he cannot connect to the internet until he can use the keyboard
  • 191 Answers
Connect a USB keyboard ...you can use a desktop system's keyboard
log on to acer website and install drivers
Posted on Jun 05, 2008
  • Rahil Kamra
    Rahil Kamra Jun 05, 2008
    if its win XP you can click on start
    go to all programes
    click on accessories
    click on accesibility and choose on screen keyboard in case you don't have a wired keyboard
Acer 5570z keyboard is locked..Mouse works fine. Tried it in safe mode..keyboard still wont work..but mouse will...Even reloaded the operating system and keyboard still doesnt work..
Hook an external keyboard to the laptop, if okay! replace the laptop keyboard. If no change check bios setting to make sure the laptop is not disabled, and reset bios to factory default.
Mar 10, 2012 | Acer Computers & Internet
Microsoft wireless media desktop 1000
attached a USB or PS/2 keyboard with your laptop and goto control panel and double click on add or remove software select the software which you can installed & delete it. Actually this fault reason virus or otherwise reinstall your operating system.
Nov 11, 2009 | Acer Aspire 1640Z Notebook
I was in the middle of cleaning up my laptop (deleting stuff i do not want on my laptop) and when i had finished my keyboard did not work(built in keyboard) nor my built in touch mouse keypad did not...
This usually works for most device problems. Go to the device manager and scroll down to the mice and pointing devices as well as the keyboard. If the keyboard and the touchpad are listed in the device menu, then you can right click on the device and click on update driver. Windows will search update for a fresh driver. If the devices are not listed, then go to Acer support (link below) put in the model of the laptop....Aspire > 1640Z and a list of downloads will come up. Download the drivers for the keyboard and /or touchpad. After they are downloaded, run the apps, they usually self install.
If they are listed in the device manager (device manager is in the control panel....in XP, look in the system flder under the hardware tab.) and the above fix does not work, then scroll down to them and when you right click, Hit un-install, but keep the drivers. Do this one at a time and let the system reboot after each uninstall. Windows will detect the device and load the driver for it.
Oct 20, 2009 | Acer Aspire 1640Z Notebook
My Acer Keyboard wont respond when i press the key's
A few days ago my acer laptop aspire 1640z , began to behave slower than usual when typing on the keyboard. At first I thought it was a virus, I did all the necessary scans and found none.
I then thought it might be the Keyboard driver, but it wasn’t.
I went into safe mode by keeping F8 down when you start the computer and select the directory service restore mode, which resets certain applications back to its original state. I found that my internet AOL connection and explore and fire fox would not connect to the net. Make sure you have a disk for AOL or setup file for fire fox saved, to reinstall the software. This seemed to work a bit but by accident, I remove the battery from my laptop and kept the power cord connect and Wow! it works even faster than before.
I have also notice that my battery does not hold a charge anymore. My theory is that because the battery is in critical status when connected to laptop…. (Even though the power cord is connected), the computer thinks that its going to run out of power and wants to go into hibernation mode which slows everything down including typing on the keyboard.
So before you try the safe mode option, remove the battery and use only the power cord cable and see if this solves the problem. Mine is running fine again ,but when I put battery back it slows down again. I read on the net its affecting only Acer Laptops, probably because the way the power settings software is set up for the Acers.
Stephen P
Oct 25, 2008 | Acer 90.46907.001 Keyboard
Laptop pointer not working
remove the battery and run of the mains. Most likely that the battery is faulty and causing all the components to run slowly.
Oct 18, 2008 | Acer Aspire 1640Z Notebook
Keyboard and touchpad stop workin
you can check with function key or try connect other keyboard to your lap possible your keybord i broken and you need exchange for new one
Aug 08, 2008 | Computers & Internet
Acer Aspire 1640z keyboard removal
I don't have the diagram but i can give you direction.
1. remove the power cover first (where power button is), it might have 3 screw that hold, if there is 3 screw on the power cover, remove it first.
2. after your removed the power cover, you can see the screw that hold keyboard. remove that screw and you can remove the keyboard.
Jul 30, 2008 | Acer Aspire 1640Z Notebook
I have an ACER Aspire 5600 laptop. The keyboard or mouse will not respond or function (apart from F2 and Alt/F10 which work intermittently). A remote mouse works but a remote keyboard does not. I have...
Your acer bettery is the problem. I had the same problem just go to this website www.acerbatteryrecall.com/AcerWeb and fill out the form and they will send you a battery for free. In the mean time if you want to use your acer laptop just take out the battery and use only with the wall cord, you wont have any problems......you can thank me by sending me a myspace message at myspace.com/j_hambino
Jul 04, 2008 | Computers & Internet
How do I remove the keyboard on my Acer Aspire 1640z?
Ok,
Usually there are hidden screws under the screen.
usualy under some clip or something.
if you find them unscrew the keyboard.
DO NOT YANK IT OUT!
carefully remove the cord .
PLEASE SEND A PHOTO OF THE LAPTOP for further info
Jun 30, 2008 | Acer Aspire 1640Z Notebook
Keyboard,sound,touchpad all not working keyboard, touchpad and all usb ports stopped working
kINDLY CONNECT A USB KEYBOARD AND/OR MOUSE TO TROUBLESHOOT THE NOTE BOOK IF USB KEYBOARD/ MOUSE (EXTERNAL NORMAL USB DESKTOP KEYBOARD MOUSE). THEN WE WILL BE ABLE TO TROUBLE SHOOT
Feb 29, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 1640Z Notebook Logo
398 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
