Question about Siemens Washing Machines
The hinge to the door is very stiff with limescale
    Novelist:
  • 177 Answers
Clean off the lime scale with a lime away product, be very careful Limeaway is an acid. READ the products directions.
Posted on Jun 07, 2008
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 | Ovens
The Door is very stiff when opening and closong
Disconnect machine from Power.
Spray some WD40 or similar product over the hinges while you work the door into the closed and open position, until it all loosens up.
If this does not work then the hinges must be so badly corroded inside that they will need replacing.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 23, 2012 | LG WM2277H Front Load Washer
My 1999 vw beetles doors ae heavy to open and close very stiff
Use WD40 on the hinges and let soak in for ten minutes. wipe off the excess then apply White lithium grease to the hinged area and swing the door open and closed at least ten times to work in
The lubricants can be purchased at any discounted Hardware store to save money
May 17, 2010 | Volkswagen Beetle Cars & Trucks
Whirlpool GMC275PD build in electric double oven
I have a different model Whirlpool oven but if the door opens downwards then there are usually two smalll catches on top of the main hinges. Lift these up (they can be quite stiff) away from the oven, partially close the door and it should lift upwards to free the hinges.
Hope this helps
Sep 14, 2009 | Ovens
The door can barely be opened on a Wolf oven. The hinges are
I called Wolf customer care and they are sending me a new door. No Charge. NOW THATS CUSTOMER CARE.
Jul 09, 2009 | Ovens
1995 Chevy suburban back door hinges too stiff
Lubricate the hinge or the hinge will have to be replaced.. I recommend wd40 first, then a finger tip amount of grease on top of hinge pin. the oil from the grease will keep the hinge constantly lubricated. It's not too late.
May 22, 2009 | 1995 Chevrolet Suburban
GE TFS28PB Lower Hinge on Fridge door defective.
you have to get cam closure part # wr2x9246 and door stopper wr2x9247
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door very stiff won't close tight
I have the same problem with the side doors of my 04 express. I put penetrating oil on the hinge pin with a hypodermic needle (hard to find). It is important that the oil gets into the hinge. I bent one set of hinges and broke a hinge because I waited too long to oil the hinge. The door may not close correctly because the hinge may be slightly bent. Keep all other hinges well lubed especially during the winter months when the hinges can be exposed to road salt. Fixing a bent hinge is difficult at best.
Aug 28, 2008 | 2004 Chevrolet Express
Viking Ultraline Professional Gas stove
It is visible the hinges /w40 has extension nozzle spray the hinges a few minutes open slowly/ by moving little by little until the lubricant or oil penetrate the moving parts of hinges ,
Jan 01, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Stiff screen on laptop
Can you please tell me what is the notebook model
you should not lubricate the hinges
Oct 19, 2007 | Computers & Internet
Washing Machines Logo
195 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
