When i start my computer it seem as if it is own but no display is seen processor seem to be working i have shown to many hardware engineers they feel its motherboard issue.After this problem arose once my PC worked at that day I carried out installation the other day also i performed some programming work on my PC but latter the problem again remains the same. Please suggest me the solution for this and also let me know any service center in pune (india).
yes im feeling the same problem but the processor fan spins, it ll give a beep evrytime i boot my pc but aftr getting this prob theres no beep sound n display.. i think theres a prob with the bios , flashing the bios ll rectify this prob? if so how to do it ,i hope i can get the solution here, thanks in advance
nagu..yes im feeling the same problem but the processor fan spins, it ll give a beep evrytime i boot my pc but aftr getting this prob theres no beep sound n display.. i think theres a prob with the bios , flashing the bios ll rectify this prob? if so how to do it ,i hope i can get the solution here, thanks in advance
nagu..
AnonymousJun 12, 2008
my display is working but colour is vey bad, is it possible to diable the display and use an external display card for Intel D845GVSR Motherboard,
do u have any experts to repair the display problem in mumbai.my display is working but colour is vey bad, is it possible to diable the display and use an external display card for Intel D845GVSR Motherboard,
If your pc has windows xp sp2 or later and Windows Media Player 11, please follow this steps: 1. Connect the player to the computer. 2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed. 3. Select Hardware tab, and open Device manager. 4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX. 5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed. 6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next. 7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method. 8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option. 9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed. 10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
first click start in the computer then click run then type CMD then the dos modebox will be seen then type ipconfig then you will see ip adress of the network to which you are connected then type ping the ip address if the pinging is ok then your laptop is comunication with the router if no pininging or ip adress right click my computer then click properties then hardware then device manager and check wether the network adaptor is marked if marked reinstall the driver and restart the computer
computer hardware - (computer science) the mechanical, magnetic, electronic, and electrical components making up a computer system
hardwareC.P.U., central processing unit, central processor, CPU, mainframe,processor - (computer science) the part of a computer (a microprocessor chip) that does most of the data processing; "the CPU and the memory form the central part of a computer to which the peripherals are attached"
constituent, element, component - an artifact that is one of the individual parts of which a composite entity is made up; especially a part that can be separated from or attached to a system; "spare components for cars"; "a component or constituent element of a system"
computer, computing device, computing machine, data processor, electronic computer,information processing system - a machine for performing calculations automatically
computer memory, computer storage, memory board, store, memory, storage - an electronic memory device; "a memory and the CPU form the central part of a computer to which peripherals are attached"
scheduler - computer hardware that arranges jobs to be done by the computer in an appropriate order
sequencer - computer hardware that sorts data or programs into a predetermined sequence
upgrade - hardware that provides better performance than an earlier version did
computer science, computing - the branch of engineering science that studies (with the aid of computers) computable processes and structures
How about try changing your display setting, go to control panel. Double click display icon, click settings, click advance and monitor. From your monitor settings change screen refresh rate to 60 Hertz and click ok and ok. Try to restart your computer and observe.
Does it have any beep sounds on switching on( some computers won't produce beep sound) or does your monitor is not getting any signals from computer even though it is ON and has shown any message or menu screen of Monitor functions then, You will be having a faulty RAM or your Graphic port has some hardware malfunction.Or it can be also from a new unsupported hardware installation that will prevent computer from booting up.
If your monitor does not provide any of the above monitor functions successfully then It would be a monitor problem. Check wires or cables of monitors or contact nearby technical support
Download and install the firmware updater.
If that doesn't resolve, your player may really have a hardware issue. The battery is not replaceable by the consumer. My reccomendation is to exchange it with the store. If that fails, redeem your warranty through Sandisk (hope you saved your receipt).
This is due to using outdated hardware. Its not necessarily any one thing. Sure, more RAM and a new video card (even an upgraded processor if possible with your main board) will help. But if your computer is 5 years old, you need a new one for gaming purposes.
I've seen your problem countless times, and if you don't have an upgradeable computer, or its a name brand pc, you will need a newer one.
The reason it seems to get worse, is that #1, your hardware just gets older as time goes on, and #2, games become more sophisticated, resource intensive, and have higher system requirements.
Your computer can no doubt handle a lot of things without issue, but games, anything video intensive, or that require a high % of RAM, processor usage, or video usage are going to give you problems.
Unfortunately it sounds like the processor fried. These are very prone to heat degradation.
Link to computer gate Link2 Link 2 is to Geeks.com Link 3 Take your pick Your board supports Northwood/Williamette processors with HT in 400/533/800 Front Side Bus
I have to agree "...that the motherboard's bios doesn't recognize the processor and that I should upgrade the bios...". Though I think that this is only a display issue and not necessarily true CPU speed. You can check if the correct CPU is displayed inside Windows by right click on My Computer and details would be shown in the System Properties.
To upgrade the BIOS:
1. Determine/log your current BIOS and its date by pressing Pause on initial boot when motherboard details are shown;
2. Continue booting by pressing escape and run your Windows normally. Go to the website of your motherboard manufacturer and verify if they have an updated BIOS (compare date of release). If an updated BIOS is available, download. Likewise download the flashing utility. Further instructions are also available on a step by step procedure. Some newer mb versions/models have a Window based update feature. Check if you have such.
Hope this be of some help/idea. Post back how things are or should you need further information.
Good luck and kind regards.
nagu..
same
