Question about Lexmark Wheelwriter 1500 Typewriter
Spacing How do I change my sapcing from double to single spacing?
  • Lexmark Master
  • 3,594 Answers
Press code and press the line space/reloc key the lights will change to indicate spacing 1, 1 1/2, 2, 3.
DickyO
Posted on Jun 09, 2008
Double spacing
Before doing anything else, highlight all the text (including any 'white space' that might follow), that you want to change into 'single' spacing. Then go to top menu 'Format' then select 'Paragraph' and on the new menu find 'Spacing', Then on the pull down menu select 'single' and 'OK'
Jan 14, 2014 | Computers & Internet
How to fix line spacing to single space on word pad to type a letter. i have it on single space but still does double space
when in wordpad there are couple of things in blocks
clip board, font, paragraph,insert,and editing
2x spacing will be in the paragraph block its the top row right corner
if u hover your mouse over it reads line spacing click it and change it to 2
that should fixya up
good luck on the letter
Mar 29, 2012 | HP Computers & Internet
When I open Word 2007 to write a letter, or anything taking more than one line, each additional line is in double spacing. How do I change to single spacing as it did in Word 2003?
Your normal template has probably been edited to double spaced text.
To fix this you need to edit your normal template file - it will live inside C:Program Files/Microsoft Office/ Templates or a folder under this or something similar to this.
Open your template and change the line spacing to single, then save it over the existing template.
Feb 23, 2011 | Microsoft Office Word 2007 Home and...
How do I change line spacing from double to single spacing? Whenever I commence to write a letter the second line is at double spacing as are all succeeding lines. How do I get it to single spaced lines?
Open a NEW, CLEAN document. Alter all the paragraph setting until you get them exactly as you want them.
Now the tricky part.
Save the document as a TEMPLATE and save to a folder you are familiar with. Give it a good name and below that on the dialog box, choose TEMPLATE (file type dotx)
Next time you need to type a letter with single spacing, open that template. When you go to save it, Word will prompt you for a file name as a docx, thus preserving your template for another day.
Feb 22, 2011 | Microsoft Office Word 2007 Home and...
New doc spacing automatically goes to double.
use the shift + enter to get single line. else you need to save a template that includes single line.
Feb 23, 2009 | Microsoft Office Professional 2007 Full...
Single space
It may be following orders ;-) check the software you are using to see if the printer is being told that you want double spacing.
Jun 26, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Trying to type and single space
You can change this by adjusting the line spacing option.
You are talking while typing wright.
You can select the whole document by Ctrl+A.
Right click & select the paragraph option.
You can find spacing & line spacing.
In the line spacing select the numbers as you like.
Its better to use it as 1.5.
And click on ok.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Microsoft Windows Vista Ultimate Edition
Documents in single space print in double space
There may be a dip switch somewhere on the printer which enables/disables the extra linefeed. If both CR (carriage return) & LF (linefeed) are both enabled, you will get the double-spacing. In years past, I've run a few different Epson dot matrix printers, and seems like they had such a dip switch. Also, on the software end, you may be able to disable either CR or LF- check in your printer driver software.
Apr 16, 2007 | Epson LX-300 Matrix Printer
Lexmark Wheelwriter 1500 Typewriter Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
