Question about SanDisk Sansa e250 MP3 Player
I tryed to re format
I tried to re format the e250 but computer still won't recconize mp3 plz help me
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
Computer can not recconize it
You can try to format the mp3 player.
Go through the : Setting>Control panel>
Administrative Tools>Computer Management>Disk management>
Try to format fat files system.
hope this help you
Regards
uttam
Dec 27, 2009 | Sylvania SMPS2017 MP3 Player
How can i delete music file from my sansa e250
try formatting the player by selecting format from the properties menu when you right click it in my computer.
Aug 04, 2008 | SanDisk Sansa e250 MP3 Player
Player Freezes on black screen format won't work
Delete everything by formatting it then activate the hold switch, press the power button, turn it on, download a fresh new firmware from the www.sandisk.com site and drag it to the player then connect the player to the computer, then initiate the firmware. try to get the latest one.Hope dis works. RATE PLZ
Jun 13, 2008 | SanDisk Sansa e250 MP3 Player
Does not support few songs format
Make sure the songs are unlicensed
May 10, 2008 | SanDisk Sansa e250 MP3 Player
HELP PLZ
i had this same problem on my sons e250. after much hair pulling i figured out that if the mp3 you have on the e250 doesnt have any ID3 tags and only a windows file name they wont show up on the e250. A real pain. Had to go through and retag all the songs that didnt have ID3 tags. After I had done that all worked.
Apr 02, 2008 | SanDisk Sansa e250 MP3 Player
HELP
what operativ system are you using? xp/vista/linux/mac ..... if you are using ubuntu or xp well try to connect your mp3 to computer and make the recycle bin emty on the device the saftely take out the mp3 be sure that it have been un mounted you must do that every time.. i am not sure this helps but i hopes...
Jan 13, 2008 | SanDisk Sansa e250 MP3 Player
Del songs
You can format the device thru My Computer.
My Computer>Device Name (e250)>Right Click and select FORMAT.
If you cant format this way, change the MODE on the device nad try these steps again.
Best of Luck.
Nov 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Video problem
You can format the device to remove all of the residual information. My Computer>Device Name (e250)>Right Click and select format. Best of Luck.
Oct 09, 2007 | SanDisk Sansa e250 MP3 Player
EVERYTHING VANISHED ANY ONE PLZ HELP
The folder is hidden. You need to enable hidden files and folders in Folder Options on your computer. If you have the refresh database failed message often., you will need to format the device. Best of Luck.
Sep 09, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e250 keeps retarting
you should try formating it. when you plug it into your computer... go to my computer right click on your mp3 player name under " devices with removable storage" click format. make sure nothing is checked. and then press start. wait till its done, and it should work. good luck. i can use some to..
May 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
