Question about D-Link Air Xpert DWL 7000AP (DWL-7000AP) 802.11a/b/g Wireless Access Point
Factory reset dwl g700ap
Quick question
  • 298 Answers
Bill,
I have here the steps on how to reset your device.
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Posted on Jun 05, 2008
How can restart the d-link model no dwl-g700ap ??
Posted on Nov 22, 2012
A version 2.0 DWL-G700AP can lock up, so that the reset button doesn't work. This has happened to one I had. You can read about it on D-Link's site. If you are on v 2.0 you should upgrade to at least v 2.1.
Posted on Aug 25, 2008
Can I use the dwl-g700ap as a repeater?
Yes, the DWL-G700AP can be setup as an AP or a repeater as long as your current wifi router is also 802.11g/b.
You can find instructions here: http://www.docstoc.com/docs/2583739/How-do-I-configure-repeater-mode-on-DWL-G700AP
Regards, Chris
May 18, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
Unable to reset my DWL-G700AP by holding in the reset button and can not connect to or ping via 192.168.0.50
Under Windows 7, press the "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Type 'ipconfig /all', and press ENTER.
Look for the IP-address for the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Jun 22, 2010 | D-Link Air Xpert DWL 7000AP (DWL-7000AP)...
Connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
Router
Modem
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Dec 09, 2009 | D-Link DWL-G700AP (S2984376) 802.11g/b...
D-Link G700AP partially reset, won't return to Factory Default.
TRY THE RESET AGAIN .... UNPLUG EVERYTHING .....HOLD RESET BUTTON IN FOR A GOOD 10 SECONDS ....PLUG UNIT BACK IN AND OPEN YOUR IE EXPLORER SITE ...AS IF YOU WERE GOING TO GO ON THE INTERNET ....IN THE ADDRESS BAR ...TYPE IN ...192.168.1.....THIS SHOULD GET YOU TO THE SET-UP PAGE .....GOOD LUCK
Jun 02, 2009 | D-Link AirPlus G DWL-G700AP Wireless...
I can't hard reset my DWL-G700AP even though i press the button longer than 5 seconds. the device doesn't reboot. what seems to be the cause?
do one thing pull out the power cable from the device after then same time put the power and press the reset button on same time press up to 10 sec after then press one or two time then you get it
Apr 14, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
I receive excellent signal from DLink dwl-g700AP but can't browse
On this tip you can find an easy check list let me know if you need more help
Feb 02, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Unable to update firmware
Your router latest Firmware I can see on D-link website is 1.02
If you are referring to German web site page showing a dwl-g700ap_fw_revB_v213b06.zip file be sure to follow the instruction to UNZIP the web_dwlg700ap_v200_r11_0408.bin file:
DWL-G700ap Firmware Update
- Browser starten
- Konfiguration des DWL-700ap aufrufen (Standard IP 192.168.0.50)
- oben auf Tools
- links auf Firmware
- auf den Knopf Durchsuchen klicken
- die Firmware Datei (web_dwlg700ap_v200_r11_0408.bin) auswählen
- auf Apply klicken
Wenn die Firmware installiert und der DWL-700ap dann neu gestartet ist klicken Sie oben auf Tools/System/Restore to Factory Default.
Danach ist die Firmware übernommen.
If you did not unzip the bin file router cannot run it as firmware update
More over be sure to run the update via LAN cable connection (no WLAN)
Jan 24, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
But the DWL-G700AP...
Is this access piont connected to a router? Can you get online through the router? If you can go online through the router also check the status of your wireless connection. Make sure its connected and it's getting a valid ip address.
Aug 22, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
D-Link Air Xpert DWL 7000AP (DWL-7000AP) 802.11a/b/g Wireless Access Point Logo
23,432 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
