Question about SanDisk Sansa m240 MP3 Player
SanDisk Trouble My sandisk will not start up it just shows me the title screen and loops it over and over again.  Any advice??
  • 8,596 Answers
Reset first.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 13, 2008
Not enough space for misic DB please free space 6mb
Posted on Jul 27, 2009
Sansa Clip Boot Loop
My Sandisk Sansa Clip + is not working, it's stuck on the Sansa logo, the Flower, Refreshing to the Media, Then, it turns back off and starts again, help me Please, Thank you.
Mar 03, 2013 | SanDisk Sansa Clip+
My sansa e260 goes black after showing sandisk start up screen and does the same when plugged into a pc. it starts to refresh database and then the screen goes black.
Hi there
When you say the screen goes black even after disconnecting the device from computer it could be an issue with the firmware.
It might need to have updated firmware. To get the updated firmware please go www.sandisk.com.
Where you can get the latest firmware for your model.
*** Make sure when you update the firmware keep the device in MSC mode.
Here is the link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
Kindly revert for further clarifications....
Feb 17, 2010 | SanDisk Sansa e260 MP3 Player
SanDisk MP3 keeps restarting and can't get to main menu
I would recommend that you upgrade the firmware on the device..Once the firmware is update you shouldnt have any problems..To update the firmware follow the link below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Should you have any other questions you can contact myself or sandisk...
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 29, 2008 | SanDisk Sansa e250 MP3 Player
Trouble with my sansa
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 23, 2007 | SanDisk Sansa e260 MP3 Player
Just a blue screen.
if the player will still play music but nothing shows on the screen, then the display is shot. The screen is not replaceable on these players. sorry, but it's most likely junk now. You could use it as a data storage device still. Best bet is to buy a used player off ebay or amazon.
Jul 28, 2007 | SanDisk Sansa e130 MP3 Player
Problem with my MP3 player...
I am having the same issue. I loaded my M240 with music, then umpluged it from the USB cable. It didn't do the "building library" thing like it always does, and now when i turn it on it just loops from the "Sandisk" startup screen to the "Sansa initiallizing" screen. The same as you, when i connect it to the pc it isn't even recongnized and the player loops the "initiallizing" screen again. I put a request in to Sandisk last night, so i might have a solution for us later today.
Jun 15, 2007 | SanDisk Sansa m240 MP3 Player
Pls help my e250 sandisk
Hi please try this steps. Turn off the player. Slide the hold switch to the other end for it to show the orange/red color. Then press and hold the menu button until it says welcome to recovery mode. Then if you haven't updated the firmware of the player this would be the best time to do it. Donwload the firmware update at their website and run it on your computer. When it asked you to connect a device connect the player and perform the update for the player hope this helps.
Jun 15, 2007 | SanDisk Sansa e250 MP3 Player
Repeating title screen
mine too i was mad :\ just got it fixed like 2 min. ago im soooooooooooo happy thank GOd ___________________________ I have the EXACT same problem and my device is stuck in MSD. Which two files are you talking about? My sandisk support rep did not send me any attachment. Thank you for contacting SanDisk Technical Support. We should be able to fix your player. Disconnect the player from the computer if it is connected. Please copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Once you have downloaded the file, please follow these instructions. 1) Double click on My Computer so that you can see it on your screen. 2) Turn the player off. 3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange. 4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button. 5) Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish. 6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left. 7) Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Jan 04, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
241 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
