Question about Epson GT-2500 Flatbed Scanner
Scanner program issues
Hi! we have xp professional running on a dell computer that will find the scanner and will open the program to the taskbar. we can't open to use it, it only stays on the taskbar. we have tried max/min the window and changing the properties of the program but nothing seems to work. the epson start up window comes up then disappears leaving the program open on the taskbar without enabling us to open the program to use it. we have restarted the computer and the scanner a couple of times. any ideas? thanks!
jene
    Novelist:
  • 110 Answers
Registry Problem and here is the fix. If you are not familiar with the registry, do not attempt this.
Now we need to remove specific references to the product in the registry:
1. Click on START and then RUN.
2. In the Run window type in REGEDIT.
3. In the upper menu bar click on FILE, then EXPORT.
4. In the window that comes up, SAVE IN should be set to DESKTOP.
5. In the FILE NAME section at the bottom of the window type in REGBACKUP.
6. EXPORT RANGE should have a dot next to ALL.
7. Click on SAVE.
8. Look in the column on the left and Click on the “+” sign next to HKEY_CURRENT_USER
9. Click on the “+” sign next to SOFTWARE
10. Click on the “+” sign next to Epson
11. Look for a folder name EPSON SCAN. Right click on it and Delete it
Close the registry and start scanning
Posted on Aug 22, 2008
  • 191 Answers
I think the drivers needs to be reinstalled provide me information regarding your scanner like brans and the model number
i'll provide you a link to download latest drivers
hopefully it will fix the issue or else we'll try further troubleshooting
Posted on Jun 06, 2008
  • Rahil Kamra
    Rahil Kamra Jun 06, 2008
    provide me information regarding your scanner like brand and the model number
Operating on Windows XP. Family tree maker8 won't open
1.Requires it to be run in Windows XP Compatibility mode.
2.Ftm.exe is not signed aka doesn't have a publisher prompting user account controls in Windows 8. (Security issue)
Compatibility mode for FTM 2012 in Windows 8:
1.From desktop, right mouse click on FTM Icon on the taskbar
2.Hover over "Family Tree Maker 2012" and right mouse click again to get Properties
3.Click on Properties
4.Choose Compatibility tab
5.Under "Compatibility mode", check box "Run this program in compatibility mode for: Windows XP (Service Pack 3)" Side note: after utilizing "Run compatibility troubleshooter" this is the resolution I got.
6.Click okay and test to see if program opens properly.
Note: due to the ftm.exe not having publisher info, each time I open file, I get security prompt to allow unknown publisher to make changes to my computer. Family Tree Maker must address this issue.
Jun 08, 2015 | Computers & Internet
Tip
How to uninstall and reinstall HP Deskjet D2360 Printer
Hi,<br /><br />I think you need to uninstall and reinstall your HP printer drivers.<br /><br />to do this follow these steps:<br /><br /> 1.<br /> Select Start , Settings , and Control Panel .<br /> 2.<br /> Double-click the Add/Remove Programs utility.<br /> 3.<br /> Select the HP Deskjet D2360 Printer and click Add/Remove<br /> 4. Restart your computer<br /><br />To reinstall HP Deskjet D2360 Printer<br /><br /> *<br /> Make sure that the printer is properly set up, turned on, and ready to print.<br /> *<br /> Check that all cables are firmly connected.<br /><br />For Windows XP<br /><br /> NOTE: You must have administrator privileges in Windows XP Professional to install a printer driver.<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />For Windows XP Home Version<br /><br /> 1.<br /> Close any unnecessary programs that are running on the computer using the steps below.<br /> 1.<br /> Right-click any program appearing on the Taskbar next to the Start button and choose Close .<br /> 2.<br /> Repeat step a. until all the programs appearing on the Taskbar are closed.<br /> 2.<br /> Click Start , Control Panel , Printers and Other Hardware , Printers and Faxes , and then Add a Printer .<br /> 3.<br /> Follow the instructions on the screen to finish the installation.<br /><br />If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response<br /><br />Thanks,<br /><br />LETMEFIXIT
on Feb 02, 2011 | HP Deskjet D2360 InkJet Printer
Tip
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit <CTRL><ALT><Delete> and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit <Enter>. Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
on May 27, 2010 | Computers & Internet
GET RID OF SOME TASKBAR ICONS, NOT JUST HIDE.
You can type at the RUN MENU : msconfig
You will get system configuration utility open
select: SERVICES and the select HIDE ALL MICROSOFT SERVICES.
un tick the box of the program you don't want.
also
on STARTUP MENU untick the box of the program you don't want .
ok
you can use malwarebyte free for 60 days to remove unwanted things in the registry
hope this tip will help you
regards
uttam
Dec 21, 2009 | Microsoft Windows XP Professional for PC
My All In One Center's Program Won't Install
Try www.twain.org for scanner driver (twain-compliant), see if you can't find an updated driver for the exisiting hardware, may solve your issue!
Aug 31, 2009 | Dell Office Equipment & Supplies
Tip
How to sucessfully repair the Taskbar in Windows XP
If your taskbar has become hidden or icons are missing read on
Close any open desktop and taskbar applications, then open your registry and find the key below. Delete the entire StuckRects2 for Windows XP, and reboot.
Press the <Windows Key> + <R> to access the run and then type regedit navigate to the following user key.
[HKEY_CURRENT_USER_Software_Microsoft_Windows_CurrentVersion_Explorer_
StuckRects2]
And then delete it when your PC restarts the taskbar with be recreated and repaired.
There are several other programs that suggest that they can fix the taskbar but this is the simplest method that I have found so far that actually works.
Note: If you want to have a clock like mine is the LongHorn Clock (aka LClock v1.62b) by Ying Han http://www.neowin.net/forum/index.php?showtopic=157465
on Jan 06, 2010 | Microsoft Windows XP Professional for PC
Taskbar hide
Hi !!
Your computer is infected by virus. Update your antivirus software and run full scan and you can also try nod32 online virus scanner.
www.eset.com
Thanks
Jul 10, 2009 | Microsoft Windows XP Professional SP2
I run Windows XP Professional. Today there showed up a second layer of taskbar. It has ''Desktop'' in light blue, ''My Documents'' ''My computer'' and ''My Network Places'' shown in white with icons. ...
You have only increased your taskbar size, don't worry...
Right-click on an empty part of the taskbar, and ensure the "lock the taskbar" is unchecked. Next, position your mouse right on the top edge of the taskbar, your mouse should change to two black opposing pointing arrows. Hold left-click, and drag the taskbar down.
This will reduce the taskbar back to the way you're used to.
Hope this helps, and please rate this answer.
Jun 26, 2009 | Dell Computers & Internet
Computer get hang / taskbar is disable
Try running this program by going to http://www.kellys-korner-xp.com/regs_edi...
and you'll be fine... enjoy. =))
Sep 06, 2008 | Microsoft Computers & Internet
Updated to Windows Vista and now the Dell 922 AIO scanner won't work
For windows Vista; it is imperative to run the Vista patch which can be found on the Dell website (Downloads and drivers).
Make sure that you run the patch, after removing the printer USB cable from the computer. Restart the computer as the patch suggests and then install the Vista specific drivers, which also need to be downloaded from Dell Website.
Again, do not connect the printer unless the installation software asks you to.
For scanner issues, those who are unable to get anything scanned to their computer, and are able to print, it is essentialy a Firewall/Anti-virus issue. You can check that out by trying to scan using an application such as MSPaint (Start> type 'mspaint' > hit enter).
Nov 01, 2007 | Dell 922 All-In-One InkJet Printer
Epson GT-2500 Flatbed Scanner Logo
185 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
