Question about Sony CDX-S2000 CD Player
CDX-S2000 Volume, Source, and Mode buttons not working????
I have a Sony CDX S2000 Detachable face CD player. It seems that the buttons on the Left side of the faces plate are not working. I have cleaned the connections on both the face pate and the unit itself per the instructions in the manual, but with no improvement. Any suggestions???
  • smarty1711 Sep 20, 2008
    i turned the volume down and now the only buttons that work are off and eject, took front apart, thought it was a button sticking but no better, reset head unit and now have sound but buttons still dont work
  • Anonymous Dec 05, 2008
    im having the same problem as Smarty1711. jus recently it just stopped workin, the only button that works is the eject and off button. the sounds works perfectly fine can someone please help me figure out the situation PLEASE!
Hey jshaff, try taking off the detachable front, and you will see a reset button, press and hold in for 10 secs, this should solve your problem. if it doesn't work first time keep trying. you must have power to the head unit for this to work. you will hear the cd make a noise and that should be that, try and let me know.
Posted on Oct 04, 2008
I had the same problem with the buttons not working although the CD did work but again the volume and track buttons did not work. The reset button did not solve the problem. I cleaned the contacts on the faceplate and head unit (with denaturred alcohol and a cotton bud) but this made no difference. I finally thought there might be a fuse problem in my car (Honda Accord). I took out the fuse for the radio/cig lighter but this was okay. But when I put the fuse back and turned the ignition on the unit made a whirring noise and when I pressed the power button the powered aerial activated and all the functions returned. Maybe disconnecting the power to the radio/cd player, which I did unintentionally, properly resets the unit rather than the button reset method.
Posted on Mar 14, 2009
Sony CDX-s2000 in 2001 KIA Sephia
did you replace the fuse behind the wireharness if so did you check the fuses in the fuse block on your radio. if so you have checked everything try under the hood of your car there should be another fuse box check in there. if all fuses are good check the ground wire on the radio
Sep 08, 2009 | Sony CDX-S2000 CD Player
Sony CDX-F5700 no longer sees Sony 10-disc changer
face plate is going bad lcd is fading solution--replace face
Jun 21, 2009 | Sony CDX-F5700 CD Player
CD RESET
to fix this problem you have to take the face plate off. There should be a small button on the middle-left side that sais "reset" on it. Get a ballpoint pen and press this button. Pop the face plate back on and play your CD and it should work no problem.
Jan 16, 2009 | Sony XPLOD CDX-GT200 CD Player
I am unable to remove face on radio plate
http://www.docs.sony.com/release/CDXRA700.pdf
Manual
States the following....
Press off, then up arrow button (bottom left corner)
Pull toward you.
Find the info on page 4 of the manual. (link is above)
Jan 11, 2009 | Sony CDX-RA700 CD Player
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
Won't turn on
remove the detachable face plate and look for the gold contacts thats plugs in with the main unit , get some Qtip and alcohol , and clean contacts ,try that , hope it works AJ
May 14, 2008 | Sony CDX-R3000 CD Player
Face plate
the face plate is not removable it only folds down
Apr 10, 2008 | Pioneer DEH-P6600 CD Player
No display
If you have tried another front & its the same, then its the main unit,...
Are the copper contacts clean? use rubbing alchol.
Are they intact? No? it needs to be professionaly repaired.
Aug 31, 2007 | Sony CDX-FW700 CD Player
Sony CDX-S2000 CD Player Logo
2,581 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
