Question about Toshiba Satellite M45-S331 Notebook
Stuck Media Card in the Machine
I accidentally inserted a sony camera disk in the mediabridge slot.
now the disk does not come out and is stuck
subsequently the computer had to be restored
when restore4d the computer gets stuck and does not go beyond when the indicator light comes on
how do i open the computer and take out the disk i could not get a diagram to unscrew the back to access the mediabridge (multi card reader)
or is there any other any other solution tot his problem
Same thing happened here. Hubby was able to remove memory card by inserting a VERY small screwdriver under the memory card and catching on an indentation. He was then able to remove the disk from the slot.
Posted on Jul 25, 2008
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
I have a camera that carries a 1GB SD and when it is inserted in the camers the camera says the card is locked, but the switch on the side of the card shows it is not locked. what can I do?
Spray dry air or contact cleaner into card slot to remove any debris...work card in and out several times should have a push-push action...pushing in card should slightly spring back...push again card should pop out a little.
Sounds like latch that catches and holds card is broke or stuck...hope it's stuck!
Jan 01, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Multi-media card reader problem
Try pushing in on the card until it clicks, and springs back out. If it is not that type of slot, then pull the card out using a pair of needle nosed plyers (since you obviously can't pull it out by hand). If it looks to require too much force, then you might want to try taking out the screws on the back of the laptop to reveal the card slot, there is an obstruction that is preventing the card from being removed. I had an issue with an SD card getting stuck, and I pulled it, but the pins stayed inside, so use caution & be gentle.
Dec 12, 2008 | Lenovo 3000 Y410 Laptop
I have a simple question. How do I insert my scandisk memory stick pro duo card into my laptop to read? MY laptop has open slot 5 in 1 media card reader. I can insert all my other card and able to read....
You need an adapter that will convert it into a regular pro duo card. They usually come with the card when you buy it but else should be availabe at you local electronics store.
Dec 03, 2008 | SanDisk Memory Media
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
Nikon D80 SD Card slot problem
Is it slightly thicker on the contact end, Or is something stuck on the flat corner? try getting a needle and picking out any plastic that could be stuck there. Is the card under warranty
Sep 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Memory stick
I think catcher-lock in memory slot is defective in your PC that's why memory card is stuck there. Use tweezers to pull it back as temporary solution and ask nearest Sony service center for replacement of defective part.
Aug 22, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Wrong memory card size insterted
Opening of your camera would not be good because memory slot has very very little space in it and you can't do any thing, use tweazer to pull out that memory card.
Jun 20, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
There is a sd card stuck where the cd should go. There is also a disk there. Do you know how to fix it?
If you can see the SD card, Get a toothpick and wrap Tape onto it then reverse the tape so that you have sticky on outside. See it you gcan retract it that way. You risk damaging the Disc eject system if you try to force the disc to eject by pressing the eject button more than 10 seconds. Once you get the SD card out you can do the 10 second eject button thing.
Nov 15, 2007 | Sony Playstation 3 (PS3) Console
Toshiba Satellite M45-S331 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
