Question about Gateway 835GM (835GH) PC Desktop
No video installed video card and worked ok . now its gone south???
    Problem Solver:
  • 14 Answers
You might try removing video card clean contacts and reinstall see if this helps.
Posted on Jun 05, 2008
Nuvi2555LMT
The micro SD card has to be between 4-8gb. Garmin Express is used to load the South American maps. Garmin Express can be downloaded from Garmin. Once installed on your PC, plug your GPS into your PC. The program should give you the option to install the South American maps to the SD card.
Dec 31, 2016 | Garmin nuvi2555lmt nuvi 2555lmt
Fix on board vga
On board video is a problem when it goes south. Probably easiest solution would be to install a video card in an open slot and move on. Have done this in the past and kept old box running for a while. VGA video cards can be found for cheap, depending on what you want for display and speed.
Hope this helps.
Oct 07, 2012 | HP Compaq Presario SR2020NX PC Desktop
Asus p7h55-m black screen when i installed video card.. then i thought my video card is not functioning.. i get it and use on board vga.. its the same problem.. black screen, keyboard no light.. no si
Have you tried removing the new video card? Try that first.
The fact that your keyboard doesn't light most likely means that either your power supply is being pulled down by the video card or is now gone. Was your power supply rated high enough wattage for your computer with the new video card? If the video card was higher-end then it's possible that it killed the supply.
It could also be the motherboard that's gone. Static discharge when putting the video card in, or a bad video card can destroy a motherboard.
May 31, 2012 | ASUS P7H55-M LX Motherboard
Powers up....no video....hard drive indicator stays on
If you have already gone into the BIOS settings and made sure it is set to power up with your internal video card then simply try installing a new card in the PCI slot. When booting with a new card (or known good used card) you should get an image on your monitor that will prove your system is ok and you just needed a video card. If that works your onboard Chip was bad. Before you start any of these checks go into your BIOS settings and set up the default settings just in case since there are setting related to amount of shared memory for onboard video that could stop you from getting any picture at all.
Jun 07, 2010 | E-Machines eMachines Desktop PC
Screen is black..will not display anything. Any
You provided very little information, so I'll try to answer:
I assume you turned on the comptuer and it seems to be working-you didn't say.
I assume it used to display something-you didn't say.
Hook it up to an external monitor. Can you see something? If so, one of two things are wrong: Your LCD screen has gone bad OR you need to hit the Fn/Special function key combo that moves the display from your LCD to an external monitor.
If none of these solves the problem, then your video card has gone south on you.
Jan 23, 2010 | Toshiba Computers & Internet
No video on new Gigabyte GA-MA770-DS3 motherboard
There are a couple things that you need to look at. The first is your power supply. I've had computers seeming to run fine with no video. Turned out to be bad power supplies.
Does your video card require a power connection? Many high-end video cards need an external power connection. If the card has a power connection, use it.
Have you gone in and checked the cmos settings? What does it say (if anything) for the default video?
Now remove all connections to drives (hard drive and CD and try for video. Try it.
Next, if possible, swap out memory.
After you've tried everything (including maybe burning incense), time to try a new motherboard.
May 27, 2009 | Gigabyte Computers & Internet
No video from the board
Check the motherboard user guide for how to reset to default factory settings. If the BIOS is set to work with the on-board only and the on-board VGA is dead the motherboard is supose to detect that and switch to AGP. If is not doing that chances are not only the on-board VGA controller is gone ... the motherboard is gone too.
Try with a PCI video card.
1.Reboot with the AGP or PCI video card installed - assuming the on-board is gone but the motherborad still OK.
2. Press DELETE key
is supose to go in BIOS settings menu.
Browse and Look for on board VGA adapter ENABLE/DISABLE setting or something similar.
(My bet ? You need a new motherboard.)
Jan 12, 2009 | Intel Motherboard
SPeaker and Headphone
If both speakers AND headphones aren't working and nothing is muted, it sounds (no pun intended) like your sound card has gone south. Have you checked in Device Manager to see if it's still listed? Right click My Computer>Properties>Hardware>Device Manager. Check under Sound, Video and Game Controllers to see if it's there. If so, right click and choose Update Drivers just in case it somehow got wiped out. That would be the easy fix and I hope it's not your card!
Thanks for using Fixya.com and please rate this tip accordingly.
Oct 18, 2008 | Harman Kardon HK695 Computer Speakers
My laptop has a faint light blue shadow appearing to the right of any black to white high contrast image or any plain black text. Is it a heat problem with my video card or is my monitor about to fail?
early warning that video is going south. could be video chip or the screen itself. happen with any other card? YOu might consider re installing the video drivers
Apr 25, 2008 | Computers & Internet
Nokia Navigator
Download and install Nokia Map loader and reload the map that you need back to the memory card.
http://www.nokia.co.uk/A4630257
Apr 09, 2008 | Lands Phones
Gateway 835GM (835GH) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
