"The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder."
That is completely wrong. DIN UNLOCK means what the first poster said - that you are trying to make a digital copy of a digital copy. You cannot (for legal reasons). Record via analog.
ABSOLUTELY DO NOT TRY TO CLEAN YOUR LENS WITH ALCOHOL AND A Q-TIP. It has nothing whatsoever to do with your problem and you may well damage or destroy the lens or the transport.
SOURCE: SONY MDS-JE480 "C71 - DIN Unlock" persistent problem
I get the DIN UNLOCK with you try to make a copy of a digital copy.
SOURCE: The problem with my MDS-JB940 is when recording.
HELLO
Have you tried cleaning the lens? Even minidisc decks have to get the laser cleaned!
Power it off and take the lid off, then using isopropyl alcohol and a cotton bud clean the lens gently in a circular motion. Then try it again.
It may just work for you (:-)
SOURCE: din unlock
Hi - You can download the manual from the link underlined in blue below:
MDS-JE480
The error you have is probably:
This means that you are trying to record from the Digital Input, if you want to record from an analogue input do the following:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
