Question about Canon imageRUNNER 5570 Copier
5570 imagerunner question
Did you ever find the toner waste container? i can't locate it
Hi All,
How to change corona wire on canon IR5570
Posted on Sep 07, 2012
  • 18 Answers
If you can find the main power switch to the machine, you can find the waste toner bottle. Find the doors on the right side of the copier that are used to clear paper jams, or find the bypass tray. Then look towards the rear of the machine and you will find a small cover where the on/off switch is located that is attached with two screws. Remove the screws, pull out the bottle and dump the waste. Slide the bottle back, reattach the cover and you are done.
Posted on Jun 08, 2008
2 Suggested Answers
  • 53 Answers
SOURCE: Replace waste toner container message on IR 5570
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter that is not included in your manual Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Posted on Jan 18, 2010
Where is the waste toner container on a canon 7065 copier fax machine
waste toner container is located in front side.open your toner door and door support front frame where the canon logo was sticked.after removing this you can see easily waste toner container
Jan 27, 2011 | Canon ImageRUNNER 3235 Black and White...
E000821-0002 ERORR WHY R U COM THE COD OF CANON IR5570
these means that copier is detected too much waste toner in cleaning blade assy.
Book says:
Clogging of toner inside the cleaner has been
detected with reference to an abnormal rise in the
cleaner thermistor.
Try to:
- Remove the waste toner from inside the cleaner.
- Replace the air filter of the heat discharge fan.
and I would also recomend to check waste toner stiring "snail" and waste toner container.
Hope that helps!
For service manual you can contact me on emma.servis@gmail.com
Sep 07, 2010 | Canon imageRUNNER 5570 Copier
What does the message mean "Replace the waste toner container on a canon np6230?
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter.
Go into maintenance mode by depressing the additional function key, then 2 & 8 at the same time, then additionall function key. Select copier, then at the top far left side select counter.
The counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Apr 05, 2010 | Canon imageRUNNER 5570 Copier
Jan 15, 2010 | Canon imageRUNNER 5570 Copier
Waste toner collection IR 5570
remove the small lower( rear)right side cover 2screw then you will see the waste bottle youcan pull it out and throw away the waste toner
Jul 15, 2009 | Canon imageRUNNER 5570 Copier
Remove the waste toner cartridge from a canon imagerunner 6020. I wasn't sure and couldnt get the instructions from the 5570 to work
i think the waste toner bottle is on right side, its on the lower level of right side of the machine there is four screws, unscrew them and empyt the bottle, but u have to clear the waste toner bottle mode after. if this machine the waste toner in the front cover, just open the front cover, left the green handle and pull the waste toner,.the empty it and put it back
Jul 08, 2009 | Canon imageRUNNER 5570 Copier
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
Waste toner container on canon imagerunner 330s
It is located below like a small box/ press beside the box to release /
www.justmanuals.com
Jan 10, 2008 | Baby Gear
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
Canon imageRUNNER 5570 Copier Logo
243 people viewed this question
old marine
old marine
