Question about Frigidaire ATF6000ES Front Load Washer
FRont loader washer
My washer less than 2 years old, says EFO or E20 with maybe 15 minutes left on the cycle, i can go and push start, and it will finish the cycle, however, if i mess the flash, i will have to start all over again? what is this
  • mamabop Jun 05, 2008
    this did not work either.could a drain be stopped up or something??
  • 868 Answers
Try this,on next load use NO deteregent/soap.Please leave a rating.
Posted on Jun 05, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 05, 2008
    ON next load and EVERY load afterward you MUST use HE DETERGENT ONLY.!!!
    Please leave a rating ! Thanx!
  • Archie Ferrarini
    body {
    background: #FFFFFF;
    margin: 0px;
    padding: 4px;
    font-family: arial, verdana, sans-serif;
    font-size: 10pt;
    p {
    margin:0px;
    padding:0px;
    .spwrap
    background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom;
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
Getting E20 error code on frigidaire front loader. It's 6 years old and has had one main panel board replacement already. Is this the same problem?
You are experiencing a pump issue. Typically a professional is needed to :
1. Check the drain hose for restrictions. Restriction, correctproblem. No restriction, go to step (2).2. Start the washer and checkfor 120VAC at the drain pump.Zero, replace the Main Control Board. 120VAC, remove the pump and checkit for blockage. If blocked, remove the restriction, if not, replace the pump.
Jul 28, 2012 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
E20
the door won't lock, then i broke the grey thing that the door prong or latch locks into by slaming the door. its a little plastic grey hole hole. i don't see what holds the grey plastic thing in the hole. or how to order it. can you help. ? but the door wouldn't lock before that, i think the 3 and 4 year old kids play hanging on the door. how do you fix it. 2006 afinity fron loader washer. thank you. cheryl
Oct 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
EFO
Try this ,do a load with no soap /detergent
Jun 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF6000ES frozen
IF there is an E attached to the 45, it is your control board and the control board would need to be replaced. This is per the "Washer Tech Data Sheet"Hope that helps...
Mar 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
94 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
