Question about Sony PlayStation 2 (PS2) Console
Unable to load playstation dics or any other discs for that matter
I have used a disc cleaner it wont load, ive taken d console apart and cleaned d laser and still nothing loads
  • 868 Answers
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Posted on Jun 07, 2008
My ps3 will not read any dics. but if i am playing a demo and then put in the disc it will read it just fine. any ideas?
go here
http://community.us.playstation.com/thread/627262?start=0&tstart=0
select option 3 when you see the menu
Thanks
1RepairStop.com
Feb 14, 2012 | Sony Playstation 3 (PS3) Console
Does not read games
Follow these steps when you are facing "disc wont read" problem
Step 1:Remove the disc from the system.
Step 2:Use a cloth to clean in small circles around the disc (not in a big circle going around the disc). Use DVD or CD disc cleaner if available. If you use cleaner, use a different dry cloth to clean the disc no more than three minutes after application.
Step 3:Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable.As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance.
Thank you !!
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
PS3 - Unable to read disc
Thank you !!
Jul 05, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont read games or DVD sometime frezze
Step 1: Remove the disc from the system.
Step 2: Use a cloth to clean in small circles around the disc (not in a big circle going around the disc). Use DVD or CD disc cleaner if available. If you use cleaner, use a different dry cloth to clean the disc no more than three minutes after application.
Step 3: Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable.As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance.
Thank you !!
Jun 19, 2010 | Sony Playstation 3 (PS3) Console
Cant read disc
Step 3: Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable. As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance.
Thank you !!
Jun 18, 2010 | Sony Playstation 3 (PS3) Console
Disc wont play
you have to clean the lense using the cd-dvd cleaner disc
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
Wont spin disc
that is a reader burn out and needs to be repaired as the unit inside needs to be taken apart if unable to repair then it will have to be replaced
May 27, 2009 | Sony PlayStation 2 Slimline Console
My ps3 have a little trouble loading ps3 game discs
You might need to clean your lens with a DVD lens cleaner disc.
Aug 26, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 (PS2) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
