Question about iLO (2 GB) MP3 Player
Start back where i left of
I have an mp3 iol 2 gig player when i turn it of and turn it back on it goes back to the front of file how can i make start where i left of
  • 8,596 Answers
You cannot - sorry.
Posted on Jul 05, 2008
I have a 2 gig sansa, and it will only let me use less that 1 gig of space. how can i use the rest?
Plug the sansa into your computer start computer right click e or f or whatever drive and format. This will erase all data on the sansa and put it back to 2 gb.
Hope that helps.
Nov 14, 2009 | SanDisk Sansa m250 MP3 Player
NO ROOM LEFT ON MY Sansa M230
If you plug your mp3 player into your computer, and it shows up in 'My Computer' - try to follow these steps.
1 Right click on your mp3 player in my computer.
2 Click on Format...
3 From FIle system menu select FAT32
4 Tick the box that says Quick Format
5 Push Start
6 wait until this process completes.
7 Safely eject the device.  (http://support.microsoft.com/kb/165721)
8 Your mp3 player should now work. If it does not try to repeat the process except this time do not tick the box that says Quick Format.
Nick
Sep 01, 2009 | SanDisk Sansa m230 MP3 Player
Ilo 2 GB Flash mp3 Stuck on ilo screen.
link your USB port between Computer and ILO player.
1.Click on START at lower left corner on you computer. choose "Explore"
2.look for ILO driver on start manu on left hand side. left click one on it. right hand click you will see the drop down options
3. Choose "Format" BESURE that you are going to format ILO NOT your hard drive. it will ask you again that you really want to format it. "yes"
4. copy new mp3 files to ILO. That will be finished. you can start playing it again.
Hope this help.
Pin
Jul 13, 2009 | iLO (2 GB) MP3 Player
Jensen SMP-2GBL 2 Gig Digital Audio Player is having an error
turns out the USB wire/connection did not go all the way into my pc because they overlapped part of it with plasic
May 20, 2009 | Jensen SMP-115 MP3 Player
Freezes after 8 secs (No sound or anything)
I registered my Sansa View in sandisk site, and the support sent to me these two solutions. I have a similar problem like you and I'm still haveing problems but meaby these steps working in your sansa view.
regards
Diego
Nr 1:
Let us update your player's firmware:
Step 1 – Connect the player in Recovery Mode.
1. Turn off the player.
2. Slide down the Hold switch along the left side of the player down so the orange is showing.
3. Press and hold the HOME button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer (XP) or Computer (Vista).
5. Release the HOME button.
Download and update the firmware.
1. Download the firmware file:
Click Here for the Sansa View Firmware update file
2. Extract the zip file.
3. Copy the extracted firmware files (*.dat, *.rom, *.mi4, and *.fnt) to the 16MB-FORMAT drive.
4. Disconnect the player. This will now start the firmware update.
5. Slide the Hold switch to the unlock position.
6. Turn on the player.
Nr 2:
It appears that this is caused by file corruption in your player's memory. Usually, formatting your mp3 player resolves this FM issue in your player.
Formatting your Sansa View Mp3 player in Disk Management:
WARNING - FORMATTING YOUR MP3 PLAYER WILL ERASE ALL MEDIA FILES IN YOUR PLAYER, PLEASE BACK UP IF POSSIBLE.
1. Make sure the Sansa View is turned on.
2. Engage the hold switch, located on the left-hand side of the player.
3. Press and hold the LEFT BUTTON ( << )
4. Connect to the computer while pressing and holding the LEFT BUTTON ( << ). Do not let go of the left button until the player is detected as Removable Disk.
5. The Sansa View should now be connected in MSC mode and should appear as a "Removable Disk" or "Sansa View".
6. From the desktop, right click My Computer, then select Manage. If you don't see My Computer on the desktop, click on Start and right click My Computer from there, then select manage.
7. On the Computer Management window, click Disk Management from the left pane.
8. On the right side, locate your sansa device on the list (it might be recognized as removable disc), right click on the sansa device, then select Format.
9. On the Format Window, select FAT32 under File System and make sure that the Quick Format option is not checked.
(You might get a warning window about your files being deleted when you format the device, if that is not an issue for you, click ok.)
10. Click OK to start formatting the device. This should start the format process.
11. Once the formatting is done, unplug the device from the computer. Let the device refresh.
12. We can verify that formatting is successful if it shows no files on the player.
Oct 25, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Won't upload media
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Jul 27, 2007 | Philips HDD1630 MP3 Player
Help me fix my daughters ilo MP3 player
if either the power button or the lock switch or used while its loading the player will reload or shutoff
Apr 30, 2007 | iLO (2 GB) MP3 Player
Error copying file or folder
You can always reformat it. If you plug the mp3 player into your computer and right click on the icon in the MY COMPUTER window, and click on FORMAT. It should come to a new window and click on start format. Your fixer, Wild2DMaxx
Jan 17, 2007 | SanDisk Sansa e250 MP3 Player
iLO (2 GB) MP3 Player Logo
16 people viewed this question
Top iLO Audio Players & Recorders Experts
Sanath Kumar V
L Pfaff
L Pfaff
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
