Question about Acer Computers & Internet
How to clean screen - Acer Computers & Internet
  • 191 Answers
Get a screen cleaner from market use a soft cotton piece of cloth to wipe it .
Posted on Jun 05, 2008
How should we clean our TV screen from finger prints?
To clean your TV correctly, follow these steps:
  1. Turn the LED TV off, let it cool for a few minutes, and then unplug the TV.
  2. Clean the frame of your LED TV with a microfiber cleaning cloth.
  3. To clean the screen, first try wiping gently with the microfiber cleaning cloth. If that does not work, spray luke-warm water directly onto the microfiber cleaning cloth. Never spray anything directly onto your TV screen.
  4. Wipe the screen with the microfiber cleaning cloth as gently as possible. LED TV screens are fragile and can be damaged if you press too hard.
  5. Let the screen dry completely before you plug the TV back in.
Jan 11, 2018 | Televison & Video
Tip
How to clean an LCD TV
<span>An LCD screens must be cleaned as it attracts dust like a magnet. Cleaning is risky as the screens are very sensitive and there are chances of you damaging the screen if you don't know the proper method to clean it. To help you in this read the article below to the various tips on cleaning the LCD TV.</span> <b>Tips On Cleaning LCD TV</b> <b>Basic Facts About LCDs</b> <ul> <li>LCD screens or displays should not be cleaned through normal methods, as they are not glass. LCD or liquid crystal display is a soft film and it can be damaged through improper cleaning agents.</li> <li>The popularity of LCD TV's is on a rise as they can be can be run on low battery power and also have<a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>sharp</span></a> picture clarity.</li></ul> <b>LCD Screens Problems</b> <ul> <li>LCD screens regularly gather dust and smudges and sometimes fingerprints and ink markings.</li> <li>Cleaning the screens with a <a href="http://lifestyle.iloveindia.com/lounge/how-to-clean-lcd-tv-8061.html#"><span>paper</span></a> towel, dishcloth or tap water can do considerable damage, as the screens are very sensitive. It can cause clouding and can cause damage to the pixels.</li> <li>Tap water contains chemicals like chloride and wiping the screens with it can leave a residue on the screen.</li></ul> <b>Cleaning Tips And Guidelines</b> <ul> <li>The LCD TV must be cleaned regularly for you to enjoy the proper clarity of the display.</li> <li>First of all, turn off the LCD TV and examine the condition of the screen.</li> <li>Note the smudges and the areas to be cleaned.</li> <li>To remove dusts use a microfiber cloth and brush off the dust particles.</li> <li>It is best to use proper cleaning solutions that come with LCD cleaning kits. However, you can mix one part of isopropyl alcohol with one part of distilled water and using cotton or microfiber cloth, clean the screen. Another cleaning solution that can be made at home to clean LCD TV's is to mix one part of vinegar in one part of water. Pour this solution on a soft cloth and then wipe the screen.</li> <li>Take care not to spray any sort of cleaning solutions directly onto the screen. Instead take it on a piece of cloth and then wipe.</li> <li>Wipe the screen in a circular motion and be very gentle. Don't press hard.</li> <li>Also do not touch the screen with your fingers or there are chances of leaving oily prints.</li> <li>Rub a soft cotton dry cloth to completely remove excess liquid from the screen as the moisture may damage it.</li> <li>Before switching back the TV on, let the screen dry completely.</li> <li>If some stains or marks are hard to remove, don't apply pressure to remove it. Instead, repeat the cleaning procedure several times to get rid of it. For ink marks and other hard stains, you have to invest in special cleaners.</li> <li>To clean the dirt from the edges or corners use a Q-tip. Dip one end of the Q-tip in the cleaning solution and squeeze out the excess moisture from the cotton tip. Now gently drag this tip along the edges.</li> <li>Do not use cleaning solutions that contain ammonia, ethyl alcohol, acetone, toluene, ethyl acid, or methyl chloride. These chemicals can react with the LCD screen materials and damage it.</li></ul>
on Jan 18, 2011 | Televison & Video
How do I clean the screen?
Disconnect the power to your TV before you clean it each time.
Choose either lukewarm water or a cleaning solution to clean your TV. Commercial cleaning kits that include both a cloth and cleaning solution are available. These cleaning solutions are specially formulated to clean flat screen TVs and monitors safely and are specifically labeled safe for "laptop screen" or "LCD screen." If you wish to use a solution, you must use one of these.Dampen a soft cloth (preferably chamois, micro fiber or 100 percent cotton) with either the lukewarm water or cleaning solution. Just a gentle wiping of the screen is enough. Rubbing, scrubbing and hard pressure can damage the screen.
Mar 15, 2011 | Televison & Video
HOW TO CLEAN GREASE LOOKING SPOTS OFF THE SCREEN
Hi, LCD screen is quite different with crt screen. You should be careful while do cleaning. Unplug the power supply before do cleaning.
How to clean lcd screen: You can use isopropyl alcohol, hexane, petroleum benzine, glass cleaner with ammonia free.Apply the liquid to soft and clean cloth then wipe your screen. Repeat the steps until your lcd clean
Grease look on screen? Just use dampen cloth with water instead use above liquids as the may smear the contaminant across the screen.
Regards, Jay
Jan 20, 2011 | Hitachi 57F500 57" Rear Projection...
How should I clean it
You should use a dry, soft, non-static cloth to remove dust from the screen. And, YES, the unit should be turned off before you clean it. Halos are usually caused by pressing too hard on the flexible screen covering when cleaning or by static electricity (VERY BAD!!) from your cloth.
If you should ever need to clean the screen more thoroughly than a dry cloth will do, dampen your cloth with clean water and wring out completely (the cloth should only feel damp...not wet) and use that to clean the screen. NEVER use any sort of household cleaner on the screen, such as ammonia, liquid glass cleaners, or detergents. The screens are tough but more liable to become damaged through incorrect cleaning.
Dec 01, 2009 | Vizio L37 Television
Plasma tv scratch
Things You’ll Need:
* Television screen cleaning products
* Cleaning schedule
* Microfiber cleaning cloth
Clean Your HDTV Screen Properly
Step1
Read the warning labels on all your household cleaning products. Even glass cleaners might not be suitable for use on an HDTV screen, so check the manufacturer's warnings before you apply anything to the screen.
Step2
Keep chemical cleaners away from your HDTV on cleaning day. The harsh chemicals found in most common cleaning products will actually cause more harm than good.
Step3
Leave liquid cleaners under your sink when cleaning your HDTV screen. A liquid cleaner, whether it be water or a chemical cleaner, will drip down the screen and work its way into the interior of the TV, causing damage to your HDTV. You will be able to easily recognize when this happens, because your screen will develop smudges.
Step4
Use a cloth to clean the HDTV screen. Ideally, you should use a cloth that is recommended for HDTV screens, computer screens and other electronics. The word "microfiber" may be imprinted on the packaging.
Step5
Wet the microfiber cloth slightly. Just a hint of dampness is all you need. If water runs out of the cloth, then it's too wet and will cause smudges.
Step6
Develop a regular cleaning schedule for your HDTV screen. If you dust the screen daily, or at least several times a week, with your microfiber cloth, no other maintenance should be necessary. Not only will frequent cleanings make caring for your HDTV easier, but they will also enhance your viewing experience.
Step7
Prevent messes by asking family members and guests not to touch the television screen. You should also try to make sure children with sticky fingers do not come in contact with the screen.
Step8
Use a high-end cleaning product if you feel that regular dusting is not sufficient. Top-of-the-line television cleaning products are ideal for use on all HDTV screens, plasma screens, projectors and are safe to use around children and animals.
Aug 11, 2009 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
