Question about Motorola Mobility RAZR V3
Screen come on but very very faint
The screen inside and out comes on but very faint. Can only see in very bright natural light
  • 94 Answers
First reset ur phone then if it dont work open the lcd portion and pres the jack. ur lcd should work. reply me
Posted on Jun 05, 2008
Can only faintly see black screen
inverter is bad..
if screen has a little white 2 pin jack, which plugs into a little board
then its that little board is bad .if it has one gold jack
alone and plugs in at bottom of screen , then its screen bulb bad
new screen !!!
Jan 19, 2014 | HP PAVILION G7-1219WM Laptop Screen 17.3...
Powers on, no display
Do you have sound? If so, dim the lights in the room and shine a bright flashlight on the screen and see if you have a faint picture. If you have a faint picture, you have a backlight problem. On most of those sets, the backlight inverter is combined with the power supply so that power supply/inverter board will more than likely be the culprit!
Dec 07, 2013 | Vizio E420VA 42 in. LCD HDTV
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
Dec 16, 2012 | Sony KDL-32M3000 32 in. LCD Television
Bright white screen with faint images
If lighting did strike, you would be suffering power supply problems, due to a power surge from the strike.
The problem sounds like it could be related to the LCD panel becoming faulty or if your able to test inside the unit with a multimeter, you can measure the voltages from the printed circuit boards, especisly those suppling power to the LCD panel as well as the Logic PCB, A small printed circuit board you will find either attatched to the LCD panel. I hope this helps.
Good luck.
Jun 07, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
No brightness visible on screen, but positioning at an nagle you could faintly see the proram open.Tried adjusting light dimmer but tono avail.e
try pressing Fn + F8 to increase the screen brightness and Fn + F7 to reduce brightness.
If this does not make any difference, then it means your screen bulb is dead and needs replacement.
Once you replace your screen bulb, your screen will brighten up again.
Good luck.
Apr 12, 2010 | HP Pavillion dv9740us Notebook
Video screen on a compaq nx5000 is very faint. Suspect an inverter problem.
if the display is faint, try to increase the brightness using ur Functional key (Fn) & ur Functional Key (F4, F5, or F6)
Dec 13, 2009 | HP Compaq nx5000 Notebook
My dell e1404 laptop is having a issue with the screen. When you turn on the computer the screen will come on for about 30 seconds and then go off. When it's on everything looks normal. once it goes out...
The inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. The inverter board converts low voltage DC power (few volts) supplied by the motherboard to high voltage AC power (few hundred volts) needed for the backlight lamp.
When the inverter board works properly, the backlight lamp gets power and the LCD screen lights up. As a result, the image on the screen is bright. If the screen is dimming down, means that the inverter is failing in it;s job to supply the needed voltage to the Backlight.
The Inverter is mounted underneath the display screen and is connected by a two wire plug.
Nov 07, 2009 | Dell Inspiron E1405 Notebook
My screen is dark when the computer logs on (but I
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness.
Sep 24, 2009 | HP Compaq nx9030 Notebook
Faint picture on screen
Most likely the backlight on your LCD has gone out. See http://www.inventgeek.com/Projects/BacklightFix/Overview.aspx for a guide on replacing the backlight.
Nov 10, 2007 | IBM ThinkPad T22 2647 Notebook
Motorola Mobility RAZR V3 Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
