Question about HHP IT3800 Handheld
HHP IT3800 don't read well, when the front red glass is scratched
Is the front red glass available for replacing?
Whe have more than 200 units installed
thank you
regards
Get a polishing solution, like for CD and DVD's and clean the glass, that should impove dramatica.lly the performance
Posted on Aug 05, 2008
Remove last digit on a it3800
You should try downloading the configuration manual from Honeywellaidc, it should probably be there still.
When you have the setup book, search for data transmision options.
Apr 14, 2014 | HHP IT3800 Handheld
Se me a desconfigurado mi hhp it3800 quisiera las barrar para resetearlo o el manuel
Here you will find the user's guide:
http://www.geoti.co.kr/DATA/hhp/IT3800_3900%20Users%20Guide.pdf
Hope it helps!
Best regards!
Rafael
Jun 09, 2011 | HHP IT3800 Handheld
I have an IT3800 scanner and use it in a gift shop. My products have "regular" barcodes, those with 5 digits added and ISBN barcodes. My scanner stopped scanning the extra 5 digits. I went to the IT3800...
What you need is to turn on Digit Addenda for the types of barcode you are trying to scan. Here is the user's guide:
Please check page 7-30, where you will find the codes to turn on the supplements for EAN 13 barcodes (those with 13-digit). Also, if you don't want the scanner to insert a space between the main code and the additional digits, you have to turn off addenda separator (page 7-31)
There are similar configuration codes for other symbologies (like UPC A) throughout the manual.
Hope it helps!
best regards!
Rafael
Sep 01, 2010 | HHP IT3800 Handheld
How do I remove an 'A' from a barcode? The barcode we are scanning has an 'A' encoded in the front of it. We are trying to remove the 'A' from the string so only the numeric characters following it remain.
What format is the barcode?
You should be able to program the scanner to from a leading digit or specific digit. We did something very similar to this, but I don't remember if it was a Symbol or HHP scanner.
Manuals for this scanner. http://www.honeywellaidc.com/Site.aspx/na/en/support/technical_support/retired_products/retired/?product=251
Apr 03, 2010 | HHP IT3800 Handheld
Programming the scanner for Quickbooks POS 8.0
You need to program this scanner, I can provide any manuals you need. You can always contact me directly akowalski@legacyglobal.com or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Aug 21, 2009 | HHP IT3800 Handheld
Scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Apr 02, 2009 | HHP IT3800 Handheld
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
HHP IT3800 scanner will not run as Power User only with Admin rights on XP Pro
You may be able to resolve this if you allow power users modify access etc to the the installation folder of the HHP scanner software.
This needs to be done as an administrator.
This can be done by opening explorer and going to the root folder of the software. Firstly you need to ensure that simple file sharing is disabled - to do this go to tools - folder options and click on the view tab. Scroll all the way to the bottom and uncheck enable simple sharing. Click ok. Now right click on the folder go to the sharing and security option in the popup menu. Click on the security tab and click on ADD. Type in power users in the input field and click ok. In the permissions area enable modify and write access.
This should fix the problem.
Apr 24, 2008 | HHP IMAGETEAM 3800LR Handheld
It3800 barcode scanner problems
Will it scan data into excel or word?
May 21, 2007 | HHP IT3800 Handheld
HHP IT3800 Handheld Logo
249 people viewed this question
Top HHP Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Don A
Don A
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
