Question about Sony Handycam DCR-DVD203 DVD Camcorder
Lens Cover will not open
Recently, my lens cover will not open. I've tried plugging it in, resetting it and manually opening but nothing works. Any suggestions?? We have experienced the same problem with our Sony DCR-DVD203. The camera was working fine one moment and has not been abused, but now the lens cover will not open.
    Genius:
  • 3,422 Answers
Try forcing open the lens cover with a tissue and blow. Try a couple of times.Few people have reported success with this issue..
Goodluck,
Please don't forget to rate or accept the solution..
Posted on Jun 05, 2008
  • 3,037 Answers
You have tried manually opening it, you say? How were you doing this and why didn't it work? Is there an error message coming up on the camera at all? We are talking about a Sony Handycam correct? or what camera are we talking about because your description of the problem seems to be two different things. Please update me on this and answer my questions and I will see what you can try that you haven't done already.
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 05, 2008
    If this is a regular digital camera and not a video camcorder, then try to gently bump it with the palm of your hand as either there is some foreign material within the lens area or possibly the gears are off or your motor is bad and the bumping will usually fix the first two
  • Benjamin Patri
    you may also try blowing compressed air or blowing by mouth to get any material out.
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Sergeant:
    Champion:
  • 230 Answers
May be the lens cover got bent or there may be obstcles that struks and will make the lens cover not to open so try by giving it for service
  • balachander megavarnam
    balachander megavarnam Jun 05, 2008
    check whether the battery is charged
    Brigadier General:
  • 3,614 Answers
Make sure that your device battery was fully charge, or make sure that the unit has a power on it..
thank you
The lamp cover light is blinking then projectoe gose off
hi,
There is two possibilty for this problem one is the lamp cover is not properly placed and the second one is the lamp has reached end of its usful life span.
First of all check the lap cover is propely placed or not. if its ok then try to reset the lamp hour.
For that press the menu button and select setup and then select Lamp setting and reset the lamp. It is reccomented that the lamp reset should only be don after replacing the lamp.
OK
Oct 06, 2011 | Sony Bravia® VPL-AW10 Projector
Panasonic SD H80 Lens cover
Make sure gas valve is turned on. Make sure spark plug is not soaked. If has has a primer, only prime it about 3 times. No more than 5
Jul 03, 2009 | Panasonic SDR-H40 HDD Camcorder
Lens cover won't open
You should look for "lens cover mechanism" when open camera front cover. This part has defective gears or misaligned some thing internally. Part detail is as under for Sony DCR-DVD653E model.
( 1-787-236-11 ) MOTOR UNIT (LENS BARRIER)
You can have an idea of this part in below exploded view... I hope these info will be useful.
Oct 29, 2008 | Photography
Lens Cover Won't Open
NO Super glue this can be fixed pretty easily to get fixed. most local shops will not charge you to much to fix it maybe 15 to 20 at the most i figure. or you can remove the lens cover by putting a very small flat head screw driver on the side of the lens and with the camera off pull away from the camera and it should just pop off. Superglue if you get it on the lens will rune the whole thing. Just tiring to help out . I repair lens shutters all the time they are just mechanical parts nothing really special about them.
Apr 16, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
No startup on lens cover opening
well the problem it´s on the switch that turns on the camera that is located under the lens cover.... this swith is glued to the front cover and lots of times gets unglued, u need to remove the lens cover by removing 2 screws on the bottom part of the lens cover, after that just pull the switch slowly and glue it. don´t use 3 seconds glue use a more viscose one. good luck
Feb 14, 2007 | Olympus Stylus 400 Digital Camera
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Lens Cover will not open or close
OMG! I had the same issue and blew on the lens. To easy to be true, but it worked! I thought maybe it was a fluke, so I turned the camcorder on and off several times, and it worked every time! Sure beats the $341 Sony was going to charge to fix it!!!!
Aug 23, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony Handycam DCR-DVD203 DVD Camcorder Logo
398 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
