Question about Mitsubishi XL8U Multimedia Projector
Lamp Meter: Where do I look for it?
Thank you!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
On the Control Panel, if you press the up-arrow, enter, and down-arrow buttons at the same time you get the usage screen. The hard part is selecting the three buttons at the same time. It takes me multiple tries to get the combination correctly.
Posted on Dec 02, 2008
Just hold that combo down until it pops up! It'll only take a few seconds.
Posted on Dec 08, 2008
My toshiba 52hm95 i still without a picture replaced the lamp and the ballast,the color wheel spins(cut the knob with the plastic tip attached from the lamp access door to get it to power up while firing...
did you change the bulb or the bulb with housing. 2.5 volt is start up volts. this is to check if the bulb is there or not. check that you have the bulb connected good you can test the bulb with a meter. on rear occations the bulb may not work even a new one.
Nov 14, 2012 | Toshiba 52HM95 52" HDTV Projection...
Samsung tv,HLS4676SXIXAA,no picture on tv,these three lights are blinking, standby light, timer light, and lamp light.i need help. thank you, Linda
Hi mam the problem of your tv is the lamp, to be sure unplug the unit from the ac outlet, then try to check the lamp filament if damage but be sure not to touch the lens and use a gloves this lamp contain mercury be sure that the lamp is properly secured. after replacing the lamp be sure to reset the lamp hour meter. Feel free to send feed back good day and best regards.
Sep 20, 2011 | Televison & Video
Hi i have a sony lcd projection kdf-e50a12u and as i turn it on the green light flashes for a few minutes untill it turns to red along with the light next to it and stays red?
Sir check the lamp of your projection if already damage, if damage replace the lamp and reset also the lamp hour meter. Remove the screws to open the panel labeled "lamp" on the back of the Sony TV. Remove the screws that hold the lamp in place inside the TV. Pull the lamp out. Let me know what is your observation to the lamp so I can guide you. Good day and best regards.
Sep 15, 2011 | Sony KDF-E50A12U 50" LCD HDTV
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Jan 29, 2010 | Panasonic 52LCX1516 52 in. Television
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
SPLIT for Models:
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Mar 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi XL8U Multimedia Projector Logo
177 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
