Question about Whirlpool Washing Machines
Hello. i have a Whirlpool LCR7244HQ2 wash not won't stop filling. it will overflow not matter on what it is set.
    Genius:
  • 1,028 Answers
Lift console ..2 screws in rear on each end... ckd for small almost clear hose to water level control be sure it is all the way on small port on contrtol ck to be sure small hose is not mashed where it goes down at back of cabinet ckd for small hole in hose
Posted on Jun 06, 2008
Whirlpool thin twin lt7100xvn0 wont complete the fill cycle
sounds like a bad water pressure switch not to difficult to do and not to costly. if its defective it will continue to fill and overflow never going into wash cycle. ( u can check it by having it set to wash and removing the long clear plastic tube hose from the tub not the switch, and blow into it, or u can use another small tube and insert it into the pressure switch & blow into it. if it starts the wash cycle the diaphram in the switch is ok if it doesnt the switch is bad) and u may want to check ur inlet water valve as u may have a bad water inlet valve. which can also keep water flowing no matter what u do even when unplugged from wall. Have u ever noticed water in the tub for no reason like the next day? these can be checked with a multimeter.
Jan 15, 2015 | Whirlpool Washing Machines
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
Water won't shut off at specific load capacity
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps,
Gene
Aug 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
May 30, 2009 | Whirlpool AWZ412 Front Load Washer
Frigidaire Washer/Dryer flse60rgs1 Starts filling but won't stop no matter what setting its put on it just fills the tub, and ultimately overflows
The problem is most likely the float switch or it could be a stuck fill valve. If it is the fill valve, it will stop filling if you unplug the machine.
You can find the parts and diagrams at partselect.com
If you need more help, post a comment.
Thanks,
Tim
May 14, 2009 | Kenmore 22642 Top Load Washer
Whirlpool Estate Washer will not stop filling.
There is a fill switch that is not being triggered. Find out where that is. The dog hair could be the culprit. This switch is but cutting the tank fill. God Bless John
Apr 16, 2017 | Estate ETW4400VQ Top Load Washer
Our washing machine keeps filling with water and overflows. It will not stop filling with water no matter what setting it is on.
ck for stuck open fill valve ..with power unplugged does it keep filling if so valve if overfills only during fill cycle ck waterlvel control and associated hose to side of tub look for kinked or otherwise pluged line also possible pin hole in line
Apr 26, 2008 | Washing Machines
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Washing Machines Logo
62 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
