Toshiba 27wlt56b TV - No picture
I have bought a 2nd hand Toshiba 27wlt56B for UK which does not have a power supply??? I have a power lead (3 flat prong connector) which fits into the TV. When I switch the TV on the and press the remote the standby light turns to green but screen remains the same (no light and blank). Is there something that I should read into the TV not having a "power supply" which is actually in the TV itself or is the TV faulty?
Thanks,
Martyn
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Posted on Nov 24, 2008
welcomejee
  • 10594 Answers
SOURCE: 32LG3000 LCD TV shows no picture when resuming from standby
It seems just channel stored data issue.
Please perform Auto Preset / Auto Channel / Auto Tuning (mentioned menu items) and store all channels again.
Hope problem will resolve.
Posted on Dec 18, 2008
  • 41 Answers
SOURCE: tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
  • 187 Answers
SOURCE: rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
Why is my tv saying when i try to set it up no signal. it is a toshiba 27wlt56b can you help please ?
It only says "no signal" on the screen, when it does not get a signal. So check you did plug in the correct cable from your antenna or receiver. Also check the cable for bad contacts. Do check an antenna amplifier if it gets the power it needs (when used)
Feb 22, 2015 | Toshiba Televison & Video
How do I change the language from Japenese to english in my 27Wlt56B Toshiba TV remote control?
If you factory reset, you can then select language but if you don't read Japanese, good luck!
Oct 07, 2014 | Computers & Internet
TV comes on, but, no picture, no sound
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 23, 2012 | Toshiba 50HPX95 50 in. Plasma HDTV
I bought 2nd hand Apple Studio 15" monitor without power supply- where can I find one not over £50? Is there a generic supply I could use or is it locked down to apple supplies, which are thin...
Anytime I purchase second hand devices, especially Apple, I go on Ebay.com. It sounds like you're in the UK so you may want to search on Ebay.uk to keep shipping costs down. Just type in your model. I purchase quite a few Apple products and the particular power supply you're searching for should be under 15 pounds UK.
Feb 08, 2010 | Apple Studio (Metallic Silver) 15" LCD...
Tv picture keeps going out audio does not about every two or three min.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV-32w4+
Please post back what you find.
Dec 22, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Toshiba 27WLT56B. A year ago it developed a problem: (1) I have to switch it on from the buttons on top of the TV. (2) Only after 10 minutes does it respond to the remote control (RC). (3)...
there it is a complicated problem your tv seem to have one big problem with the supply module inside him the power current was accidentaly increased and now your tv dont respond better and your picture is enlarged because had a big alimentation current and now you must to go in authorized service to fix that problem
Dec 11, 2008 | Televison & Video
New Toshiba 32'' - sound gone funny
on your remote control click menue and than select sound and go from there
Oct 16, 2017 | Toshiba CX36F84 TV
Picture size
Assuming power supply voltages are correct,ie regulated sources,you will need access to the servicer menu via the service manual or CD ROM info for that make/model.(2)reset screen control adjust on IHVT (transformer).(3)solder any/all bad connects,esp.regulator pins. Practice visual acuity technique!!
Sep 25, 2007 | Toshiba 36A40 36" TV
Televison & Video Logo
317 people viewed this question
Top Televison & Video Experts
