can be varios reason: 1) faulty motor 2) control motor defective 3) lube in shaft motor 4) mechanical device for motor defective.5) Syscom (microcontroller defective) see the block diagram
SC590: Toner collection motor error -Definition- [B] The toner collection motor sensor output does not change for 3 seconds while the toner collection motor is on. - Possible causes - · Toner collection motor defective · Too much load on the drive mechanism · Poor toner collection motor connector connection · IOB defective · Toner collection motor sensor defective
broken belt , defective timer, defective board if electronic, defective push button start switch, defective cintrifugal switch in the motor itsself, defective motor, foreign object blocking fan motor in housing, stuck drum rollers.
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool..... 1. Defective thermostat 2. Defective freezer fan motor 3. Defective defrost timer 4. Defective defrost thermostat 5. Defective defrost main heater. 6. Defective condenser fan motor 6. Defective compressor overload protector 7. Defective compressor start relay 8. Defective compressor start/run capacitor (some models only) 9. Defective compressor 10. Restriction in refrigeration sealed system 11. Loss of refrigerant (leak) 12. Excessively dirty condenser 13. Broken wires, bad wire harness connectors, ect. 14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Good day,
An ice maker is an accessory. It would not cause the refrigerator itself to not function.
Here is a list of the major reason a refrigerator will not function.
I don't know what you mean by "broke".
Items that will cause a refrigerator not to cool..... 1. Defective thermostat 2. Defective freezer fan motor 3. Defective defrost timer 4. Defective defrost thermostat 5. Defective defrost main heater. 6. Defective condenser fan motor 6. Defective compressor overload protector 7. Defective compressor start relay 8. Defective compressor start/run capacitor (some models only) 9. Defective compressor 10. Restriction in refrigeration sealed system 11. Loss of refrigerant (leak) 12. Excessively dirty condenser 13. Broken wires, bad wire harness connectors, etc. 14. Defective fan motor switch (some models only)
1. Cleaner Home Position Sensor 1 connector is disconnected. 2. Cleaner Home Position Sensor 1 is defective. 3. Cleaner Home Position Sensor 2 connector is disconnected. 4. Cleaner Home Position Sensor 2 is defective. 5. Cleaner Motor Drive Mechanism is defective. 6. Corona Mechanism is defective. 7. Cleaner Motor connector is disconnected. 8. Cleaner Motor is defective. 9. DRV PCB connector is disconnected. 10. DRV PCB is defective. 11. SPC PCB connector is disconnected. 12. SPC PCB is defective. 13. LVPS is defective.
Good day. Items that will cause a refrigerator not to cool..... 1. Defective thermostat 2. Defective freezer fan motor 3. Defective defrost timer 4. Defective defrost thermostat 5. Defective defrost main heater. 6. Defective condenser fan motor 6. Defective compressor overload protector 7. Defective compressor start relay 8. Defective compressor start/run capacitor (some models only) 9. Defective compressor 10. Restriction in refrigeration sealed system 11. Loss of refrigerant (leak) 12. Excessively dirty condensor 13. Broken wires, bad wire harness connectors, ect. 14. Defective fan motor switch (some models only)
F1 00 Content Sorter communication trouble
Detail Communication line test error occurs when
power is turned on or after the exit of a
simulation mode.
Improper communication with sorter
Cause Improper connection or broken wire of
connector or harness between copier and
sorter
Sorter control PWB defective
Control PWB (PCU) defective
Malfunction due to noise
Check
and
remedy
Clear by turning the power supply OFF/ON.
Check communication line connector and
harness.
Replace sorter control PWB or PCU PWB.
F1 02 Content Sorter transport motor error
Detail Transport motor drive trouble
Cause Motor lock
Check
and
remedy
Check transport motor operation with
SIM3-3.
F1 03 Content Sorter guide bar rocking motor trouble
Detail Sorter guide bar rocking motor drive error
Cause Motor lock
Motor speed error
Overcurrent to motor
Check
and
remedy
Check guide bar motor operation with
SIM3-10.
F1 04 Content Sorter indexer lower limit detected
Detail Indexer has exceeded lower limit.
Cause Sensor defective
Check
and
remedy
Check sensor with SIM3-2.
F1 05 Content Sorter indexer upper limit detected
Detail Indexer has exceeded upper limit
Check
and
remedy
F1 06 Content Sorter bin shift motor error
Detail 1) Bin shift is not completed within 2.5
seconds after bin shift request
Cause Motor lock
Improper motor speed
Check
and
remedy
Check bin shift motor operation with
SIM3-4.
