Question about Humminbird NS25 GPS Receiver
Moisture in antena
Where can I find an antena for a NS 25? My NS 25 quit receiving and I isolated it to the antena which had moisture in it and after drying it out it still failed to respond.
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
Please click here to find a replacement antennae for your Humminbird device.
Hope this helps.
Posted on Jun 05, 2008
    Sergeant:
    Champion:
  • 230 Answers
You can get the antenna here
http://www.ausfish.com.au/vforum/showthread.php?t=73519
and also check this
http://answers.yahoo.com.au/question/index?qid=20071005064534AAsKFCV
thanks for using fixya
you may press the accept button on my solution if you are satisfied
Garmin 550t. When i have my zumo on my motorcycle mount it seems not to take power from the bike & then after a while it tells me "low battery", it is wired directly to the bike battery so it should...
Moisture has probably gotten inside the motorcylce cradle through the connector pins. if you take it apart, there is a very small ribbon cable that attaches from the pins to the cicuit board. if moisture gets on the end of the ribbon cable it can short out the small power tracers on the cable and cuircuit board. this happened to me. i had to buy a new cradle. 85.00
May 16, 2010 | Garmin zumo 550 GPS Receiver
Moisture under screen
'standard' problem, condensation build up due to poor design planning... open the chart door for a few minutes and it will help balance the temp indifference between the inside and the outside (there is a little vent in there).
Feb 05, 2010 | Northstar 6000I GPS Receiver
Garmin had moisture inside,now screen is partly faded
Sounds like water damage, did you drop it into a lake or something? It might need a trip back to Garmin for repairs.
Jan 04, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Dropped my 765T in water please help!!!
Put your GPS in a bag of uncooked rice for a couple of days to remove moisture.
Dec 14, 2009 | Garmin nuvi 750 GPS Receiver
My Raystar 120 GPS keeps losing its fix.... the fix comes b ack a few minutes later, but then i lose it again. I have tried a cold restart, but the problem persists. Ideas?
Guys, most likely the litium battery is eol. Buy a new litium 3 volts battery for 3-4 euro's with soldering points . Use a pair of scissors, note the plus and minus side of the poles and carefully cut out the battery leaving enough metal to solder a replacement battery. Solder the replacement battery, and the problem is fixed. You're ready for another 6 years of fun saving 300 USD for a new GPS!
Oct 10, 2009 | Raymarine Raystar 120 GPS Receiver
Weatherproof Garmin GPSmap 478 has moisture on the inside of the window. Works fine. How do I remove the moisture?
Put it in a warm place for a few days. The IP rating allows immersion up to 1m so it should be OK if it's still working. I wouldn't take it apart as if you don't remake the seals properly you'll be stuffed.
Jul 20, 2009 | GPS
Raynav 300 the gps is not working
The GPS antenna with the 300 is not a GPS receiver unit like all the later Raymarine units and is no longer made. However the unit will accept input from a GPS receiver with Seatalk output. So you could use a 112, 120 or 125 receiver.
May 02, 2009 | Raymarine Raynav 300 GPS Receiver
Slow to lock on sats. unit freezes up
the set is hanging up, you have to open it try to clean battery contacts, also check for any moisture, just servicing is required.
Mar 19, 2009 | Cobra GPS 100 GPS Receiver
White oval spot in center of screen on garmin 2720 gps
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
If the touch screen is still working the moisture probably isn't between the layers. My guess is moisture got through one of the gaskets and made it's way in between the touch screen assembly and the TFT display.
If you want to clean it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the ones by the IR receiver.
Now that the touch screen is in your hand you can carefully clean the moisture from between the two assemblies. The gaskets are tricky to install again but it can be done, maybe you'll see where they were leaking.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Humminbird NS25 GPS Receiver Logo
381 people viewed this question
Top Humminbird GPS Experts
Steve
Steve
Mike Cairns
Mike Cairns
Are you a Humminbird GPS Expert? Answer questions, earn points and help others
