Question about Canon PIXMA MP160 All-In-One InkJet Printer
Ink absober full
I tried the posting by Eagle338 (Mar 10, 2008) but hit a snag - I press and hold the Resume/cancel button (#9), I then press and hold the On/Off button and NOTHING HAPPENS. If I then release the On/Off button the printer 'boots' as normal and the E, 2, 7 lights flash up on the LED in orange.
It seems that I cannot enter the 'service mode' to be able to reset the printer.
Please help, I am so frustrated.
Thanks.
  • gigamaz Nov 18, 2008
    Still Note Funtion
Service - mode in which you can perform service operations with the buttons printer. To switch the printer Canon MP-series in the “Service” mode you:
1) Turn off the printer.
2) Press and hold the button lifting / resume printing.
3) Press and hold the button printer.
4) Release the button lifting / resume printing.
5) Double-click restoration / print.
6) Release button printer.
after that time will be flashing green LED (flashing time depends on the printer model), then it will go steadily and the printer will become the “Service” mode.
Low-Level - work intended for low-level operations with EEPROM printer, in this mode MPTool works with the printer. To switch the printer MP-Series Low-Level regime should:
1) Turn off the printer on the network.
2) Press and hold the button.
3) Add a printer to a network.
4) Click lifting / resume printing.
5) Release button.
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
Posted on Jun 13, 2008
How do i fix my printer absober problem
1) With the machine power turned off, while pressing the Resume/Cancel button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Resume/Cancel button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Resume/Cancel button 2 times, and then release both the ON/OFF and Resume/Cancel buttons.
4) When the Power LED lights in green press the Resume/Cancel button 4 times
then press the ON/OFF button....
May 03, 2014 | Canon Pixma iP4500 InkJet Printer
My canon ip7240 is saying ink absober full how can i reset it ?
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. ...
  4. Keep the Power button held down. ...
  5. Release the Power button.
More items...
Reset Canon Printer ink absorber ' Fix-KB
www.fixkb.com/2011/06/reset-canon-printer-ink-absorber.html canon ip7240 is saying ink absober full how can reset it Google Search
see if this helps you out.
Apr 15, 2013 | Canon PIXMA MP170 All-In-One InkJet...
Canon printer "ink absorber almost full"
I have used my mp470 for four years after useing this fix without a problem.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Feb 11, 2012 | Office Equipment & Supplies
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
Ink absober is full
Turn off printer. Hold down Resume button and press Power button. Keep holding down Power button and let Resume button go. Press resume button 2 times then let both buttons go. Green lights will flash and then stop blinking. When green lights are solid, press the Resume button 4 times. Press the Power button and the printer should turn off, if not, press the Power button once more. Your printer should respond as normal.
Nov 10, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
I have a Canon Pixma ip1600 and the waste ink aborsorber is almost full and I have to hit the reset button to print everytime. Where is it and how do I clean it?
Jun 05, 2010 | Canon PIXMA iP1600 Printer
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Waste inki absober is full. The indicator orange
You can remove the top of the printer to remove and clean the pad or reset the printer and continue without cleaning.
These are the instructions which worked for me on my Canon pixma ip470 and has work on many other Canon models:
Feb 15, 2010 | Canon PIXMA iP90 Mobile Printer
I9950 Canon printer with message 'Waste ink absorber almost full.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release the Power
alternately in orange and green, starting with orange.)
4) 4) When the LED lights in green, press the Resume/Cancel button 4 times to reset 'Waste ink absorber'.
5) Press the Power button to execute.
Jan 21, 2009 | Canon BubbleJet i9950 InkJet Photo Printer
Error
Service mode reset - but beware resetting the counter without replacing the waste ink absorber may cause ink to overflow out of the printer.
press and hold the Power button. (DO NOT release the buttons.
The LED lights in green to indicate that a function is selectable.) .
2) While holding the Power button, release the Resume/Cancel button. (DO NOT
release the Power button.) .
then release both the Power and Resume/Cancel buttons.
orange and green, starting with orange.) .
4) When the LED lights in green, press the Resume/Cancel button 4 times. (Each
alternately in orange and green, starting with orange.) .
5) Press the Power button. The LED lights in green, and the reset is performed.
menu selection mode automatically.) .
6) Press the power button to exit service mode.
Note:- if you accidentally press the Resume/Cancel button more than 4 times in
step 4 then just press the Resume/Cancel button at least 10
times and the printer will be returned to step 4 automatically.
BTW the other functions that are available at step 4 are -
press 0 times = power off
press 1 time = Service Test Print
press 2 times = EEPROM information print
press 3 times = EEPROM initialisation
press 5 times = Destination settings (country information, do not play with
this)
press 6 times = Printhead Deep Cleaning
press 7,8 or 9 times = not used in servicing so do not play with these.
press 10 times or more = return to menu (step 4)
Jul 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
120 people viewed this question
old marine
old marine
