Question about Dell A940 All-In-One InkJet Printer
Paper feeding problem
Paper keeps pulling to the right, causing repeated paper jams and lots of wasted paper!
    Genius:
  • 3,422 Answers
HI,
There is almost always something in the paper path you can try turning it upside down and shake.
If you need anymore help let me know.
Goodluck,
Please don't forget to rate the solution
Posted on Jun 05, 2008
    Brigadier General:
  • 3,614 Answers
Make sure you use the rightr quality of paper..?
  • micromaster
    micromaster Jun 05, 2008
    Most such printing problems stem from incorrect paper types or paper loading. Make sure that your paper is loaded properly, and that the paper type is made for your specific printer.
    If paper is not feeding properly into the printer, the problem may from hardware failure. Check the feed assembly to see if all the parts are in working order. You may be able to manually advance the paper in order to see which component may be failing. If necessary, clean the paper pickup rollers to make sure the paper path is free of sticky dirt and debris.
  • micromaster
    kindly check the paper feeder assembly to see if the paper is slipping. The paper feeder requires some friction between the sheets of paper so the top sheet can be pulled into the printing chamber. Because printers use many different kinds of printing paper, you should check the printer manual to determine the specific paper type for your printer
  • 3,037 Answers
Sounds like the rollers may need to be cleaned, take an older rag and wipe down everything and also check for jammed paper in the printer.
Let me know how this goes and if this doesn't fix it, then we can see what else could be wrong
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
Paper jam too often
Here is some tips to avoid paper jam..
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams, reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what paper you should use with your printer your printer documentation will list the paper compatible with your printer.
  • Do not mix the paper you're feeding into the printer at one time. If you need to change the paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
Jan 29, 2013 | Konica Minolta Magicolor 2590M F...
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
Mar 04, 2012 | Canon PIXMA MP495 InkJet Printer
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
My espon nx300 printer keeps feeding the paper crooked. It crinkles on the right side of the paper, causing the paper to jam each time.
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Nov 03, 2010 | Epson Stylus NX300 All-In-One InkJet...
When feeding my paper it keeps pulling the paper
You need to replace the feed rollers. One side is probably worn. You should be able to buy a rebuild kit for it. Try ebay.
Nov 02, 2009 | Lexmark X2600 InkJet Printer
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper jam repeatedly
Possible cause:
The eject rollers get too slippery because of paper dust and other foreign matter.
Recommendation:
Clean the eject rollers with a paper towel dampened with water. A second cleaning may be
necessary. The easiest way to do this (without disassembling the machine for full access to
the rollers) is to hold the dampened paper towel against the rollers and make a blank print.
Clean the rollers as they turn and remove the paper towel as the paper ejects. Repeat as
necessary.
Now is a good time to also clean the paper pick up roller and feed rollers to prevent
feeding problems.
Jun 18, 2009 | Brother HL-2070N Laser Printer
HP PSC 2355 All-in-One Operating Problem
Introduction When the all-in-one detects a paper jam, the display will read, " Paper jam: Press OK to continue ." The computer might display the following message: " There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. " This document will assist in correcting paper feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. Clearing paper jams CAUTION: All paper jams must be removed from the back of the all-in-one through the rear access door. Pulling the paper from the front of the unit rotates the paper feed roller in the wrong direction and can cause damage to the all-in-one.
  1. Turn off the all-in-one and unplug the power cord.
  2. Turn the all-in-one around so the back of the unit is facing out.
  3. Open the rear access door:
    1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
    2. As the door shifts to the right, pull the door out slightly to release.
    3. When the door is released, gently remove the door by sliding the door out and to the left.
    Figure 1: Removing the rear access door c00212276.jpg
  4. Inspect the pressure rollers on the access door. They should be clean and rotate easily. If needed, clean the rollers with a soft lint-free cloth lightly moistened with water (distilled water preferred). If the rollers do not rotate easily, they may need to be replaced.
  5. From the access door opening, gently remove the jammed paper.
  6. Remove the paper stack from the paper supply tray. Discard any paper damaged or bent.
  7. Re-stack the reload the paper into the paper supply tray. Push the stack into the tray until it stops.
  8. Re-seat the rear access door:
    1. Insert the two posts on the right of the door into the holes on the right side of the opening (as shown in the figure below).
    2. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
    3. As the door shifts to the right, push in the left side of the door to lock it into position.
    Figure 2: Rear access door posts c00212277.jpg
  9. Reconnect the power cord and turn on the unit.
Causes of recurring paper feed problems If paper feed problems occur repeatedly, one of the following might be the cause:
  • Something is obstructing the paper or print cartridge path. Open the cover of the all-in-one and check for obstructions.
  • The rear access door is unlocked or improperly seated. Follow the steps above to remove and re-seat the access door.
  • The paper width guide is not positioned against the paper. Adjust the paper width guide against the edge of the paper.
  • The paper is not supported. Paper should be flat and smooth with no folded, torn, or rough edges. Some glossy and/or coated papers, or reused paper (already printed on one side) can experience a higher incident of paper feed issues.
  • The paper tray is not fully extended.
  • The paper feed rollers need cleaning. Over time paper fibers and dust will stick to the rollers and should be removed. See instructions for cleaning the rollers below.
Paper jam message displays but no paper is jammed The print carriage might be jammed. Follow these steps to correct the problem:
  1. With the power on, lift the print cartridge access door. The print carriage should move to the access area located on the right. If the print carriage stays all the way left, reset the unit by unplugging the then plugging in the power cord. If the carriage still does not move to the right, continue with the steps below.
  2. Disconnect the power cord from the all-in-one.
  3. Remove both print cartridges.
  4. Push the print carriage slightly to the left and then to the right to verify that the print carriage is not jammed. If the print carriage will not move, check for obstructions under and around the carriage.
  5. Close the print cartridge access door.
  6. Plug in the power cord.
  7. When the " Insert Print Cartridges " message displays, open the print cartridge access door and insert the print cartridges. Verify that both cartridges are seated correctly and lock into position.
  8. If the error recurs, contact HP for assistance.
Envelopes The envelope flap can move with the grip of the rollers and cause paper feed problems. Use envelopes with a rectangular flap and/or tuck the flap inside the envelope when printing. The print is skewed or crooked A small amount of skewing is not unusual with printers. When there is too much skewing, the following steps can help reduce the amount.
  1. Adjust the paper width guide to fit against the edges of the paper stack.
  2. Verify that the rear access door is properly seated and locked into position.
  3. Remove the rear access door and clean the paper feed rollers (see the instructions at the bottom of this document).
More than one sheet of paper feeds in at the same time Several paper caused problems can result in more than one page feeding into the unit. Check the list below:
  • Reused paper (paper already printed on one side)
  • Torn or folded paper
  • Textured or coated paper
  • Unsupported specialty paper
To determine if the paper is causing problems, try using clean, undamaged sheets of plain white 70 - 90 g/m2 (20 - 24 pound) inkjet paper, such as HP Multipurpose or Bright White paper. If this paper feeds correctly, the problem is probably with the other paper. Cleaning the paper feed rollers Over time dust and paper fibers will accumulate on the paper feed rollers. This can cause paper feed problems. Follow the steps below to clean the rollers: Figure 3: Paper feed rollers c00212278.jpg
  2. Remove the rear access door (as describe above in this document).
  3. Clean each roller using a clean lint-free cloth lightly moistened with water (distilled water preferred). Rotate the rollers to clean the entire surface.
  4. Verify that the paper feed rollers on the rear access door are clean and rotate easily.
  5. Re-seat the rear access door.
  6. Plug in the power cord and turn on the all-in-one.
Jun 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
56 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
seerads
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
