SOLUTION 1 - Unlock the memory card.
There is a
Lock switch on the left side of the SD card. Make sure the
Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Card lock shows up in the middle of the screen. How do I take it off ?
I have Pentax Optio L50, card locked
I have Pentax Optio L50, when i put memory card, it is showing that card locked. pls help me
thanks
venu
