Question about Columbia Telecommunications Group FRS22-SPR (22 Channels) 2-Way Radio
Frenquency and power of FRS14ND, 2 way radio
Does anyone know what the frequency range and power use is for the following model radio.
Made by Columbia. Model: FRS14ND. I let a Physicist at work use them for an experiment. Now she needs that info for her report.
Any help would be great.
Thanks,Chris
  • cw1966 Jun 05, 2008
    Perfect. Thankyou.
    Sergeant:
  • 250 Answers
Hello cw1966,
The frequencies for this unit are:
Channel / Frequency
1 462.5625
2 462.5875
3 462.6125
4 462.6375
5 462.6625
6 462.6875
7 462.7125
8 467.5625
9 467.5875
10 467.6125
11 467.6375
12 467.6625
13 467.6875
14 467.7125
Output power is < 500 mW ERP.
Hope this helps!
Ken
"Go Ahead. Use Us."
Posted on Jun 05, 2008
  • Ken Collier
    Ken Collier Jun 05, 2008
    I think it's already implied but all frequencies are in Megahertz (MHz).
Frequency range for eartec mc1000
Bendix, at one time was a good brand, however, this isn't so these days, as these are manufactured to a standard of dubious quality.
The query you have posted doesn't make sense.
Do you want to know what frequency range these radios will work on?
If so, can anyone reading this post help a friend out?
Cheers,
Peter
Jan 02, 2013 | Bendix King Eartec MC1000 Competitor Two...
I NEED TO KNOW WHAT FREQ. RANGE IS ON THIS SERIAL # 777FWLE408
Sorry, the serial number does not tell the frequency band of the radio. From this serial number I can tell you it is likely an SP50 radio, and it wwas produced Nov. 1996. You would need the model number to know the frequency band. The model number of an SP50 radio beginning with P93 would be VHF, and if P94 it would be UHF.
Note: With the mandated change to narrowband by Jan. 2013, only SP50 radios with a 00 (double zero) in the model number will do the new narrowband. Those models on wideband would have a 20 (twenty) in the model number. Example: P94YQT20AA2 would be a wideband UHF radio.
Best regards.
Aug 17, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
I need replacement batteries for a Columbia FRS14ND model 2 way radio. Which type of battery and where can I get them?
your local watch repair man can replace the battery or you can go to bestbuy.com or radioshack.com and identify the battery there by entering the watch makers information.
Jun 27, 2010 | Columbia Telecommunications Group FRS 22...
How to measure frequency with the mastech ms6100 frequency counter?
Simplest explanation is to connect signal to BNC and select frequency measurement (you may need to play around with it a bit) but it's like any other frequency counter - never used this model but if you know what the frequency you excpect then playn around until you get it
Jun 02, 2010 | Mastech Multi-functional bench Frenquency...
I have some frs14nd radios and am looking for rechargable batteries for them. Contacted the company several years aga and they said they would send me some but never heard back. can you help, thanks randy
I couldn't locate a battery pack specifically marketed for the FRS14ND, but information I did find indicates that your radios will operate on standard AAA batteries.
Bill B
May 07, 2010 | Columbia Telecommunications Group GMRS/FRS...
How to get a Talkabout T5720 to communicate with a
The frequency range and operatngmode of the two radios are compatible. To get the Radius operating on a GMRS channel you'll need a Motorola programming cable and software, OR a trip to a Motorola dealer for frequency programming. Considering the cost involved, the 2-watt output of the Radius, and the 1-watt output of the Talkabout, you would be better off performance and cost wise buying a pair of 5-watt GMRS portables.
BillB
Jan 11, 2010 | Motorola Talkabout T5720 (7 Channels)...
Modify a motorola T5500 to work in different frequency
Sorry. The MHz of your radio cannot be changed. And there are no "private" frequencies available for use. However, your radio is equipped with this in mind.
There are 22 frequencies built into the T5500, along with 38 Interference Eliminator Codes. The two combined offer you over 836 choices to avoid other people. And if this is not sufficient, they also have the capability Qt filtering.
http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Page 19: Interference Eliminator Codes
Page 21-22: Qt Filter
Apr 17, 2009 | Motorola Talkabout T5500 (7 Channels)...
Frequency determination
The number you are looking for should start out with a "H"
Example H01UCC6DB3AN, The 4th character "U", in this case denotes 806-870mhz range.
Post back with you model #
Podge
Apr 09, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Realistic expectations for transmission range
The range estunated for this radios is very poor, is related with the enviroment, the vegetation could decrese sifnificative your range. The specs for this radio says is for 4 milles, but with line of sight, every thing between the line of sight will decrese your range. Neto
Aug 20, 2006 | Cobra MicroTalk PR150-2VP 2-Way Radio
Columbia Telecommunications Group FRS22-SPR (22 Channels) 2-Way Radio Logo
641 people viewed this question
Top Columbia Telecommunications Group Radio Communications Experts
eradiostore
eradiostore
Michael
solver2010
Are you a Columbia Telecommunications Group Radio Communication Expert? Answer questions, earn points and help others
