The fan on my computer is overheating causing the system to close down, please advise as to why this is happening & how I may resolve the problem. Yours sincerely, William Hall.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey mars bar,
One of the most common reasons why a CPU or case fan will malfunction is due to built-up dust and debris. If a fan gets clogged with dust, not only can it stop spinning entirely but it can also cause internal components to overheat due to lack of proper ventilation.
Generally the simplest way to resolve this type of issue is to open your computer case and clean the interior using a compressed air disposable duster. It is important to remember though that such dusters are not designed to be used for prolonged periods and instead are meant to be used in short, sporadic bursts. Additionally, you will want to make sure that the can is held at least six to eight inches away from the surface being cleaned, as compressed air can not only leave liquid residues behind but also may freeze surfaces if they are held too close.
In the event that cleaning doesn't resolve the issue, there is a possibility that one or more internal components may be in need of service/replacement.
If you are unsure how to proceed, I would strongly suggest speaking with your local computer repair technician or a Geek Squad® agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 05, 2008
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
First try to clean all air vents with canned air, if still overheating clean interior, redo heatsinks, check secondary fans.
As you look into the vents, you may see dust build-up on foil radiators or heatsinks, not to mention on the fan assembly if it is visible. Depending the the size of the vents, you may be able to loosen up and capture some of the dust with Q-tips (cotton swabs) and **** it out with an electronics vacuum, but most technicians head straight for the compressed air. I'm not a huge fan of using compressed air to clean laptops without taking them apart, because while you'll definitely blow the dust off whatever you aim at, you'll often be blowing it somewhere else in the notebook. The immediate result will be a cooler running notebook because dust and lint build-up on heatsinks can act as a blanket, keeping the heat from being radiated and convected away, but if all you've accomplished if throwing that blanket over some other hot components that aren't visible through the vents, you may have greater problems in the future. Make sure you use a canned compressed air sold for cleaning electronics, otherwise there may be harmful propellants or liquids mixed in. Read the instructions, and if they tell you to always hold the can upside up, be careful to obey, because holding it upside down may result in squirting liquid
  • 191 Answers
Check if the fan at the back of your system is working
if its not get it replaced
My acer aspire ax 1300 is shutting off at startup and it gets hot plus the fan is running really slow making noises and it keeps showing windows error recovery it keeps shutting down? please help? it...
Your CPU is overheating. When this happens the safety mechanism causes your computer to shutdown to prevent further problems. The CPU fan will need to be replaced.
Apr 09, 2014 | Acer Computers & Internet
Tip
Laptop is turning off by itself.
Hi.
If your computer turns off after idling for a while, then check power saving settings, accessible from control panel.
If laptop turns off while you are using it, try first reinstalling the system to exclude system problems, or test the laptop starting OS from CD or staying in Bios settings mode, so to exclude installed system.
If laptop is still shutting down, then problem may be overheating.
Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
on Oct 25, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2610us overheating causing laptop to slow down?Is this because my laptop battery died
Overheating is not caused by dead battery. The most common cause of it is a faulty system fan. If the fan has mechanical defect or has degraded performance due to accumulated dusts and particles around it, it will cause overheating. Overheating can cause system to slow down at first, then if you keep using it without minding the overheating problem, your laptop can freeze and shut down on its own.
Here are some tips for overheating issue:
- Use canned air to blow out dust and particles from the system fan.
- Do not operate the laptop in areas where the temperature is high, it will worsen the problem.
- Replace the fan if you notice that it is not working properly as before cause it will further damage the laptop.
Hope this helps.
Jul 09, 2011 | HP Pavilion dv2610us Notebook
CPU fan failure causes system to aromatically shut down..
Without a proper working cpu fan the cpu will overheat and shut the computer down... if not fry the cpu. You will need to replace the cpu fan and hope the overheating didn't mess up the cpu or something on the motherboard.
Jul 06, 2011 | HP Hewlett Packard HP-COMPAQ DX2450 MT...
Model 3HLER 5437 JQ1 - 230/240 15A 50Hz Plug (fitted with13a Fuse) has overheated to the point of scorching & melting (with the machine still running). Please advise likely cause &...
The heat sensor is stuck in the open position........The sensor will click when a lighter is held close to it for a while to shut down the elements which are providing heat for drying...........Yours is staying open causing extensive heat...........Hope this helps.
Apr 20, 2011 | Whirlpool Dryers
Hello, I have a problem with my widescreen. I have a laptop (HP Pavilion dv2418ca, Windows Vista, Memory 2,00 GB, Processor Intel (R) Core (TM) Duo CPU, 32-bit Operating System) and my widescreen...
It may be caused by overheating. Overheating is the main problem with HP portables. Use a fan to cool down the computer and check how long it last working. If blowing air with a fan "Appears to fix the problem" stop using the computer and get maintenance service for it. The processor area needs to be cleaned.
Nov 23, 2010 | HP Pavilion dv4-1120us Notebook
MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP...
If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
But, if the Computer shuts down randomly, it is due to the Processor.
All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan in the Computer should resolve the issue.
Jul 05, 2010 | Computers & Internet
Ihave a laptop acer aspire4520 the problem is it swithes on no display the cpu fan rotates for few seconds and stops what could be the problem
Try to change the RAM sometime it happens because of the RAM's. Or make sure that it is not overheating thats a cause too.
May 12, 2010 | Acer Aspire 4520 Notebook PC
Hp paviolon dv2000 shuts down by itself
Hi.
If computer turns off when idle, then check power saving settings, accessible from control panel.
Computer shuts down after being on it after a while.
You are probably right. It a cooling issue. it usually happens when your heatsink gets clogged with dust or the coolant fan stops running. I have installed a softare called speed fan which automatically adjusts the fan speed according to the temperature. It will atleast resolve this issue to some extent. Also you are advised to clean the interiors of your PC with a non-static brush or duster(Dont use the normal paint brushes or a dust cloth. The static electricity can damage your chips). If nothing resolves this issue then you are probably looking at a change of heatsink.
Dec 04, 2008 | Orion (07816) Cooling Fan
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
