Question about Kenmore Dryers
Panel control hi need ur help with my electric kenmore elite dryer there are no leds light come out, no beep sounds no motor run we checked main outlet is fine and the door for dryer light is working
  • Anonymous Aug 08, 2008
    hi there i have the same thing here no power lites and no power only lite working inside check outlet 250 volts is ok anyone help with this problem thank you
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Check to see it he belt is good, there is a kill switch on the belt which will stop the operation. Could be a broken belt or bad switch. Spin the drum if it is too easy then it is the belt.
Sgt 48
Posted on Jun 06, 2008
My Kenmore Elite Oasis dryer has a CF code and continuously beeps. Running or not.
The CF error is a communication failure between the main computer and the touch panel...you may have a bad or weak connection or a bad computer..I wold recommend that you contact your local Sears and ask them about recalls, and for service should this happen again.
May 07, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I have a Elite Smartdryer HE3 dryer. Went I am about to press start it make a beep sound, but it doesn't start and give a F70 code.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 05, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Apr 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Gas Dryer-triple beep
Did you have any lights at all on the panel? I just took off the User Interface as going through the troubleshooting guide I found underneath the control panel led me to that solution.
Feb 11, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
74 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
