Question about Toshiba Satellite A45-S250 Notebook
Power Button Isn't Working Properly
The power button on my A45-S250 has suddenly stopped working properly. I press the button, and (much) more often than not, the computer won't turn on. When it does turn on, everything works fine. Might this just be a bad contact? What should I do to take care of this?
Thanks for your help!
Harry
  • komalringan Jun 06, 2008
    I am facing the same problem. and it hae been resol;ved. Thankz a lot
  • Shoharry Jun 12, 2008
    Took it to a technician. He said it needed a new hard drive. $150 for the drive and $200 for the labor. I said no thanks, I can buy a drive on ebay and install it myself (after I open the chasis and check the wire!).
    Thanks.
    Novelist:
  • 142 Answers
There might be possibility that the cable connected from the front board on/off socket which connects to the motherboard is not connected properly , so for this either you will have to open up the chassis of the laptop and then check that whether it is fine or not.
Other wise
Take a magnet and move it along the power on /off button for 1 minute ( on the laptop ) , this will remove any static charge effecting the laptop ( very rare scenario ).
Or take it to a technician.
Also check the battery.
Posted on Jun 05, 2008
Driver toshiba satellite a45-s250 wireless network connector
Toshiba Support > Satellite A45-S250 Notebook PC > Atheros 802.11 a/b/g WiFi driver with Cisco WPA support for Windows XP and 2000,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=555703&rpn=PSA40U&modelFilter=A45-S250&selCategory=2756709&selFamily=1073768663
HOWEVER, it requires the Atheros Client Utility v2.4.2.18, to be installed. If it isn't installed on the laptop, this utility needs to be installed first. Then the Driver above.
If you need guidance in downloading, or installing please post in a Comment.
Regards,
joecoolvette
Oct 08, 2011 | Toshiba Satellite A45-S250 Notebook
My laptop is not display for a week now it is MSI 10X Series
hi
if your laptop is booting properly then foll up following steps
First of all if you can remove the ram memory DO IT SO ifyou cant try without removing FIRST.
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK ANDCONTUNUE TO USE YOUR LAPTOP
May 26, 2011 | MSI MegaBook S250 Notebook
My toshiba satelite A45-S250 doesnt start the windows, it keeps rebooting and I am not being able to install it again, my dvd drive isnt working
Unplug the power cord, take out the battery and hold the power button down for 10-15 seconds. This should take your computer out of the reboot loop that it is stuck in. If it doesn't, try using an external CD drive from Wal-Mart or Radio Shack, your computer should register it and you can load the windows CD from there.
Mar 12, 2011 | Toshiba Satellite A45-S250 Notebook
HOW TO GET TO THE RAM IN A45-S250
You will find the memory on the Toshiba A45-S250 under the keyboard. Snap of the grill that also has the on/off button on it, just above the keyboard. You will find two screws holding down the keyboard and another screw near the middle holding down a small silver piece that is holding down the center part of the keyboard. Lift the keyboard from the screen end toward you. Memory is located under a clear plastic flap.The power should be off and the battery removed during this operation. Be sure to touch some metal piece to ground yourself also. Good luck.
Jan 06, 2010 | Toshiba Satellite A45-S250 Notebook
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Safe mode button for toshiba satellite windows xp a45
Press and hold F8 while booting up to access Safe Mode functions which include Safe Mode with Command Prompt and Safe Mode with Networking. Hope this answers your question. Best of luck!
Greg
Nov 05, 2009 | Toshiba Satellite A45-S250 Notebook
Power light blinking
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Sep 19, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite A45-S250 PC - where is the ram located?
The memory is under the keyboard on these models. Remove the plastic piece with the power button, and you will see the screws for the keyboard. Don't forget to rate me (fixya). thanks
Jul 31, 2008 | Toshiba Satellite A45-S250 Notebook
Labtec keyboard quit working suddenly
Here is the sequence to connect keyboard and mouse to receiver:
Press Connect button on receiver, and within 10 seconds press the Connect button under the mouse. Wait 15 seconds. Then press the Connect button on the receiver and within 10 seconds press the Connect button under the keyboard.
-- Thatpat
Feb 25, 2008 | Labtec 9675120403 Keyboard
Toshiba Satellite A45-S250 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
