Question about Quasar VM-L152 Camcorder
Power shuts on and off when I hit eject button
I can not get my camcorder to open when I hit the eject button. I hear noice but nothing happens. The power goes off when I hit the eject button then if I continue to hit it the power comes back on. Any suggestions.
I have the same problem
Posted on Jun 21, 2008
How does the cassette door open when i push the button nothing happens does the camcorder have to be on
Without details of the make and model of camcorder, it is difficult to give a definitive reply. However, all the camcorders with which I am familiar require power in order to perform any function, including ejecting the cassette. An attached battery may be sufficient, but if not, then I feel that turning it on may be the next step.
Jan 02, 2016 | Video Cameras
Canon XL2 - eject button issue
Yes, it seems a loose contact on the button's circuitry. The only way to repair this is to take it in for servicing, unless you're willing to live with it :)
Oct 12, 2008 | Canon XL2 Mini DV Digital Camcorder
Shuts off when eject button hit.
does it open when you when you connect it direct to the wall scoket.
Jun 04, 2008 | Quasar VM-L153 VHS-C Camcorder
Please help was mistakenly opened my camcorder DVD canon 230 dc the disc drive before the power on so now i can't eject it .
I had been asked you about my camcorder dc 230 canon, the disc cover is not open when I hit eject, you told me first to put on the surface Then I put it after several time it showed me on the screen the disc cover is open. but no action happen still it was stack after I fellow the manual
That you tells me Turn off the camcorder, disconnect the compact power adapter
And remove the battery pack. Restore the power supply and try again. After that it open and working correctly thank you I appreciate.
Jul 29, 2014 | Canon DC230 DVD Camcorder
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
Satellite a135-s2356 aill not boot up
a friend had same issue , i dissembled laptop and found a burnt diode chip beneath where power button sits on top cover panel there are two clips under power button , one of the clips shorted the diode , only orange power button would lit up on front edge of lower case
Apr 25, 2009 | Toshiba Satellite A135-S2356 Notebook
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
Tape eject
I have the same camcorder SONY DCR-TRV130 and have had this same problem.
The first time this happened, I was able to eject the tape by turning the unit to VCR, removing the battery then putting battery back in and pressing the blue eject button. Now 2 years later, same problem only the same solution did not work. I read many other solutions, and found one I had not yet heard of. They mentioned using a straight edge..... I was confused, but learned that the point is to try to press the blue eject button without having to completely open (lift) the door. I was able to use a strong paperclip (opened up or unfolded) I reached in with the paperclip and applied pressure to the blue button and as soon as I heard the "gears" turning, I lifted the door and the tape ejected.
Try it, I was very surprised that it worked. This has been a problem for me for about a month. I am pleasantly surprised to have a solution. Hopefully it will work for you too!
Sep 15, 2008 | Video Cameras
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Nov 13, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Quasar VM-L152 Camcorder Logo
42 people viewed this question
Top Quasar Video Cameras Experts
Josh Whitehead
Josh Whitehead
Michael Allcock
Level 1 Expert
Are you a Quasar Video Camera Expert? Answer questions, earn points and help others
