FixYa.com
Tags:
Toshiba 50H81 50 in. Rear Projection Television
Toshiba (by 4 users)
posted by raalb492 on Jun 05, 2008
the red on my tv is shadow , my touch focus is given me a error message when I try to do manually , I can't get the red line to move and the letters in red are not strait looks like a arch
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by UDown, posted on Jul 13, 2008
My problem is probably the same. My red is out of whack, so it looks like I am watching a 3-D movie without the glasses. The red is out of line, so everthing has a red shadow. I have not tried anything to resovle this.
Comment by Guest, posted on Jun 12, 2008
I have a blue shadow on my screen,I went step by step to adjusting the color convergence,I can focuse every color,but the blue will not move towards the center to aline with the cross,it let me move everry other direction but to the left.
Thanks Rolf Gosswiler rgosswiler@cfl.rr.com
Comment by eeansyweesys, posted on Jun 10, 2008
My set shows a blue tint to the outlines of the faces and the lettering. It makes it look almost like a blue shadow. The shadows lean to the left on the left side and then on the right they lean out to the right. This ahs jsut started..I also noticed my screen is alot darker whn it shows an image with little lighting.
Best Solution
posted on Jun 05, 2008
Helpful (85)
Slinteriors
Rank:Guru Guru
Rating: 88%, 2214 votes
your convergence ICs need to be replaced. There are two of them they are both STK392-110 you can get replacement Ics and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Rating Locked! (?) raalb492 has rated this solution as Helpful
Can you Help with these Projection Televisions problems?
Toshiba 50H81 50 in. Rear Projection...
Toshipa model 50h81 50...
Hello and thanks for your help,... Answer This...
toshiba 50h81 2001 rear...
It only displays green picture!... Answer This...
Replaced convergence chips,...
I replaced both convergence... Answer This...
toshiba projection tv
blank screen hurd a pop then... Answer This...
scrambled picture
We bought this TV in appx.... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
